6.0 OEM Injector Questions - Ford Powerstroke Diesel Forum
Old 07-14-2009, 05:23 PM
I have two late build injectors that are supposed to both be Ford part # 4C3Z-9E527-BRM.
One of them has gray plastic on it and is stamped International part # DA1878284C91, while the other has black plastic on it and is stamped International part # DA1846692C2.
Also, the one with gray plastic on it has Reman04 stamped on it, while the one with black plastic does not.
My question is, are these both in fact Ford part # 4C3Z-9E527-BRM, and correct for use in a late build 6.0 (in this case a 2006 6.0)? I'm guessing maybe the black one is a factory original injector, and the gray one is a reman'ed unit, although both boxes say REMANUFACTURED.
Could someone please cross-reference the International part #'s to see if these are both the same injector? Thank you
Old 07-14-2009, 05:42 PM
say no to rolling coal
They should be the same.
Old 08-04-2009, 06:53 AM
Solved!
DA1846692C2 is the original (new part - not reman'ed) Ford P/N 4C3Z-9E527-AA injector which is no longer available from Ford.
DA1878284C91 is the current Ford P/N 4C3Z-9E527-BRM injector which is remanufactured.
You can tell the difference by looking at the color of plastic on the solenoid. Black = original / new injector, and gray = remanufactured injector.
Hope this helps!
