WTF surging and cutting out under load - Ford Powerstroke Diesel Forum
Old 07-13-2009, 06:29 PM
sorry i posted this in the wrong forum....GRRRRR
2005 F350, auto transmission, dually 4x4
163K miles
Not sure what's going on but ever since I had the head gaskets replaced, the egr and oil cooler replaced and the installation of a block off plate in the up-pipe, when I get the truck to about 2200 rpms under load, it starts cutting out and acting like it's hitting a brick wall.
Cruising at that speed, usually around 65 to 70 miles an hour, it's okay but begins the cutting out trying to get up a hill or accelerating.
Anyone know what's up with this? I had the latest ECM flash done in April after the head gaskets were replaced so I would think I'd be okay?
HELP! I'm going TDY for a few weeks and would like to resolve this issue upon my return
Old 07-13-2009, 11:22 PM
Do you still have the original STC fitting?,, sounds like it could be a high pressure oil issue, or bad IPR valve. Any hard start issues?,, any smoke? any codes pulled?
Old 07-15-2009, 03:01 PM
Those are good questions. I don't know the answers to all of them but there is no smoke, no cel and I haven't checked for codes.
Checking any of that looks like I might as well replace the stuff related to the hpop correct??
Old 07-15-2009, 03:26 PM
It could also be the ICP sensor, but the IPR or STC fitting leak are probably more likely candidates.
Old 07-15-2009, 10:49 PM
Don't just start throwing parts at the truck, that can get needlessly expensive in short order. You need to get the truck on a good scan tool such as AE, and check for any codes that may/or may not be present, and also check ICP and IPR duty cycle. It could be a number of different things based on the info presented. But without more info its throwing darts in the dark.
Old 07-15-2009, 10:50 PM
Agreed,,
Old 07-16-2009, 02:04 PM
This is some of the best advice on the internet!!
