Oil Change - Ford Powerstroke Diesel Forum
Old 07-08-2009, 05:13 AM
Oil Change
Ok so at first I heard to use rotella 15w-40 now I'm hearing don't use it run valvoline premium. What oil to use? 04 F250 live in south Fl. 75000 miles.
what ye say
Old 07-08-2009, 05:18 AM
I like to use motorcraft oil, I've heard you shouldnt use rotella in a 6.0 but i dont know for sure.
Old 07-08-2009, 05:45 AM
Feedback Score: 5 reviews
i like Valvoline or motorcraft oil
Old 07-08-2009, 07:49 AM
I uses Valvoline. Either that or Motorcraft. Also be sure to use MC filters.
Old 07-08-2009, 07:52 AM
Can you get the motorcraft oil filters at walmart or do I need to order them from like dieselfilters.com
Old 07-08-2009, 07:59 AM
Im not sure about that. I get mine at the International dealer or you could go to Ford.
Old 07-08-2009, 08:48 AM
just went to tamiami ford wanted 28 bucks for an oil filter.... called the coconut point ford 18 bucks both are motorcraft.
Old 07-08-2009, 08:52 AM
I use rotella 15w-40 in my 6.0 I bought the truck used with 72,000 miles and just changed the oil this morning at a 107,100 and no problems. I have also only used rotella in my diesel tractors with no problems.
Blee
Old 07-08-2009, 12:46 PM
its all marketing,.. i've used rotella and cant bad mouth it. i use motorcraft just because its what the dealer uses and its more affordable. either way, change it at regular intervals no matter what flavor and you're golden.
Old 07-08-2009, 12:59 PM
Oil
I run val blue in my truck and I never had any problems with using it. Great oil. I also run wix oil filters. Both mc oil and filters are good product, but I get the other products very cheap through by buisness. Other comments from other post state the truth that if you change your oil and filter often with most of the name brand products you should be good. This is all just my thoughts hope that it helps.
