6.0 and 6.4 problems - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-07-2009, 02:42 PM Thread Starter
I have a 2006 f250 6.0 and a 2008 6.4 f350.
Both are in the shop with same problems. 06 egr cooler head gaskets oil cooler. All bad.
2008 egr cooler oil cooler
2006 82000 miles
2008 45000 miles
Does for and International not see the problems with these motors.
I run trucks stock no mods. I am really pissed at ford rite now.
May have to go to dodge or chevy. My 06 stays broke more than running.
I have complained about a small oil leak running down both sides of the engine and truck has been in shop 5 times still leaks oil.
06 started out with bad injuctors at 8000 miles. Turbo at 12000 and power stering pump. At 30000 more injectors and hpop. At 60000 egr cooler and egr valve. At 82000 another egr cooler head gaskets oil cooler and sensors.
Why does ford not fix problem and stop the patch jobs. I like ford products but thay need to find and fix the powerstroke issues.
ewwilborn is offline
post #2 of 4 Old 07-07-2009, 02:56 PM
f350powerstroke's Avatar
2006 82000 miles
2008 45000 miles
dont expect dodge or chevy to solve your problems ive read over on the cummins forums guys are on thier 4th turbo around 20k miles, etc. the problem mainly imo is the emisions crap, deleting the egr ,cat,dpf and muffler may solve the headaches.
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
post #3 of 4 Old 07-07-2009, 05:42 PM
mdub707's Avatar
2006 82000 miles
2008 45000 miles
For the most part, the 6.4 motors are a LOT better than the 6.0's and I'm surprised you have issues.
The other stuff with the 6.0, I'm surprised your EGR stuff lasted that long. Get the ARP studs in and delete the EGR system (including cooler) and it should be a lot less problematic.
Good luck getting that oil leak fixed. Almost every 6.0 on the planet has the famous bellhousing drip.
DamnKids Motorsports
2006 F-250 6.0 4x4
Innovative Diesel Tuning 466/772 7/19/08
VEGISTROKED
mdub707 is offline
post #4 of 4 Old 07-07-2009, 05:50 PM
winchester33's Avatar
sh*t happens, i am really happy with my truck but maybe you'd be happy with another brand. i'm probably a ford boy for life though.
2008 Ford F-250 6.4L
winchester33 is offline
