250 VS 350 - Ford Powerstroke Diesel Forum
Old 07-07-2009, 09:18 AM
250 VS 350
moving from a DRW 350 CC to a CC 250. Only problem is not a lot that I like on the market. There is a lot of 350's though (single rear wheel) MPG is still important to me since i have to drive a lot. what would be my MPG difference in a 250 VS 350 CC 6.0? Im guessing there would be due to the towing capacity extra weight.
assuming everything is stock, Ill factor in the slight lift and tires later.
Old 07-07-2009, 09:27 AM
Almostdunfukinwidit
the only difference between the 250 and 350 in those years is the block in the rear suspension. 250 has a 2 in 350 has a 4in. Other than that you can order a 250 and 350 exactly the same
Old 07-07-2009, 09:28 AM
They are the exact same except for the block and I like the 350 srw because they sit higher
Old 07-07-2009, 09:31 AM
great...as long as I get the same mpg, i have a lot more options now!
thanks guys
Old 07-07-2009, 09:33 AM
The mileage all depends on what gears you have and the 250s and srw 350 usually have the stock 3.73s.
Old 07-07-2009, 09:40 AM
ya i was going to check the gears, i was mainly wondering about weight, if it had any factor.
Old 07-07-2009, 09:46 AM
Almostdunfukinwidit
250 and 350 srw depending on options should way almost exactly the same
Old 07-07-2009, 10:03 AM
My crewcab, longbed 350 weighs in at 8k. That's using the scale at the landfill.
