Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 07-03-2009, 08:48 AM
falcons693 falcons693 is offline
fuel and oil pressure guage
for fuel guage is it better to get a fuel filter cap with an 1/8npt port on it already there and get my pressure readings from there?
same with oil pressure get the oil filter cap with 1/8npt port on it. oil pressure would be for hpop
Diesel Performance Parts | Source for Diesel Parts | Low Price Truck Parts | Ford | Dodge | Chrysler | GM
Is where I saw the caps at.
Thanks
Old 07-03-2009, 02:08 PM
work&play work&play is offline
I think you get a better fuel psi reading from the test port in the side of the fuel bowl.
This is where I have mine and it works well.
I don't know about the oil psi.
Old 07-04-2009, 10:49 AM
uncertain uncertain is offline
I have not done this, but on my old IDI I placed the oil gauge in the oil feed to the turbo.
Old 07-05-2009, 06:24 AM
npccpartsman npccpartsman is offline
Agreed about the fuel pressure reading. You can get an adapter hose from ITP that screws directly into the test port and the fuel pressure sending unit screws into the hose. The HPOP reading you can take from the OBD-II plug as it's monitored by the ECM, I believe. Taking an oil pressure reading from the oil cap would only give you LPOP.
