Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 07-02-2009, 04:49 PM
smokersteve smokersteve is offline
learning something new
an Old time diesel grease monkey and I were sharing thoughts and he told me that diesel do need some "slight" back pressure.
Ever since I heard that they do need some pressure a while ago on this forum iv been searching like crazy on this forum to read up on more.
He said that only down pipe is too Little and with the cat its too much(perf wise). 3.5 dp to 4 is good and 4 tb is good.
it was all about 6.0 and diesel in general. and he loves AMSOIL
Im not trying to get a huge confliction here but just throwing out my info. but please go ahead and comment
Old 07-02-2009, 04:52 PM
ianstew ianstew is offline
wah wah wah
i've heard that like a 5 inch straight pipe on a stock truck hurts performance a little bit, (read that in DP mag, so who knows....) but i would think a turbo charger would be enough BP on a diesel..............
Old 07-02-2009, 04:56 PM
o yes I meant with a turbo. with out of course the eng would need bp
Thanks for the comment
RRonning1984 RRonning1984 is online now
Heavy Equipment 911
I dont know one way or another but I would like too!
Old 07-02-2009, 05:02 PM
wah wah wah
i kinda messed up my post, i guess i could sum it up by saying that if a big turbocharged diesel needed backpressure, then the guys who run high HP sled pullers wouldn't run stacks out of their hood directly off the turbo.......at least that's how my thought process works anyway.
Old 07-02-2009, 05:05 PM
Slartibartfast Slartibartfast is offline
most 6.0's use the EBP sensor in running the engine, not just to monitor for faults. The PCM attempts to achieve a certain BP level under load. So a larger exhaust on an otherwise stock truck would be a mild improvement in power. it may also cause fault codes when the expected BP level can't be attained.
Old 07-02-2009, 08:37 PM
its the Day by day driving that bp is needed. gunning the living snot out of it is when it doesn't need any bp.
Old 07-03-2009, 02:32 PM
caryt caryt is offline
DP really isn't that bad most important is losing the kitty.
Old 07-03-2009, 02:39 PM
Dave Dave is online now
Obama sucks
Turbo creates all the backpressure you need
Old 07-03-2009, 03:10 PM
jamstoyz jamstoyz is offline
all i have is pretty much 2 ft of pipe after the dp. seems like it likes it lol. the turbo is very loud too
