Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 06-29-2009, 06:55 PM
01redcrew 01redcrew is offline
going to look at a 04 6.0 on thrusday anything i need to know or look for?
Hey there guys
On thrusday im going to look at a crew cab 6.0 with 53k on it. Basically i dony really know what to look at on the 6.0s and just wondering if i could get some help or what to look at if anything. Thanks guys for your time.
Old 06-29-2009, 06:59 PM
BDSford03 BDSford03 is offline
if its at the ford dealer they can give you the history for the vin. So you can see what recalls and problems it has had. This only tells you the problems that were noted by the ford dealer. the warrenty probably just ended so most problems would of been taken care of by the ford dealer. I got my 03 from the dealer and made sure i didnt have any major repairs.
Old 06-29-2009, 07:01 PM
its an indivdual and he has owned since 05. When he bought it he said it has 9k on it
Old 06-29-2009, 07:05 PM
TommyBoy#1 TommyBoy#1 is offline
well when i go and look at a 6.0 i usually pull the egr its easy only 2 - 8mm bolts (i believe) get a ladys foot prybar and pop its out the egr is $350 so its worth the check plus that will tell you if the egr cooler is bad ive seen alot of auction trucks with that problem in my shop
Old 06-29-2009, 07:13 PM
is that a egr delete kit or is that how much it is for a new/stock one?
Old 06-29-2009, 07:14 PM
new stock one here in colorado
Old 06-29-2009, 07:17 PM
damn thanks man for that info
Old 07-01-2009, 12:27 PM
JIM_C JIM_C is offline
Depending on the inspections where you live I'd plan on blocking the %$#* EGR cooler anyway. IF it's not already leaking, that is. If it's putting out white smoke that is also an indicator that the EGR cooler may be leaking.
Ask the guy about filter changes and whether he used Motorcraft filters. The oil and top fuel filters are easy to check. Ask if he's changed the air filter. Has he souped it up with an aftermarket programmer on the stock head bolts?
If you pull the EGR valve, yes it is two 8 mm bolts and a 6" extension would help. It will also help to have a 10 mm socket to remove the intake elbow first.
Old 07-01-2009, 01:59 PM
thanks man. I went to a dealer the other day and test drove another 04 and when i started it up it had white smoke coming out of the exhaust. I told myself i didnt want this truck and i moved on.
Old 07-03-2009, 11:11 PM
Redneck47441 Redneck47441 is offline
Ask him how often he changed the oil and fuel filters? How much towing did he do with it? When you start it watch for white smoke or anytime during the test drive! Pull the cap off the degas bottle and check for any signs of puking (any white stuff around the degas bottle) that's all I can think of right now! Make sure if you do purchase it change your fuel filters and oil and filter even if he says he just changed them only use motorcraft filters good luck!
