Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 06-28-2009, 03:10 PM
hoosier golfer hoosier golfer is offline
Help!!! Loosing Power/Cutting Out!!!
Ok guys!! I'm not exactly sure what the heck is going on, but when I take off and give her he!! she starts to cut out, miss, someting.. It happens once it get up between 60-80MPH under WOT. My RPM's don't jump around or anything but the truck starts loosing power and missing for a bit. Has anyone else had this problem?? I'm just trying to figure out where to start looking. And yes my fuel filters are NEW.. Thanks For All The Help!!!!!
Old 06-28-2009, 04:45 PM
bvo bvo is offline
Adam,
My 2004 6.0 is doing the same thing. Did you ever figure out the problem? If so,
please let me know. vanossforestry@msn.com Thanks!
Old 06-28-2009, 07:49 PM
smokersteve smokersteve is offline
if you got an oil or fuel guage that might tell something. Is your boost fine?? other than that I dont know.
any other info about the truck??
Old 06-29-2009, 10:48 AM
Mattdc26 Mattdc26 is offline
C-5 Crew Chief
Send a message via AIM to Mattdc26
i had the same problem man and it was one of the things the techs looked at at ford when i got mine studded they told me it was my turbo sticking whether or not thats true i dont know i hope that can narrow it down for you they replaced my turbo no problems here.
Old 06-29-2009, 10:49 AM
Abrannan19 Abrannan19 is offline
any black smoke while its cuts out or misses?
Old 07-03-2009, 11:22 PM
Redneck47441 Redneck47441 is offline
Hey Adam are you straight piped if not I could possibly see it being a dirty turbo? My buddies dodge is starting to miss alittle at wide open throttle and were thinking torque converter that could also be the case mabey?
Old 07-04-2009, 04:29 AM
Thanks for all the post's guys!! Yep, i'm straight piped!!! It doesn't smoke when it's missing, at all. My boost gauge doesn't jump or flutter when it does this either although i have had a lot more turbo flutter (fart) when I let off the go pedal under moderate acceleration. I also thought it could have been a tranny problem but my RPM's don't jump around either.. I'm leaning more towards a leaky EGR Cooler or Low fuel pressure.. What do y'all think.?.?.?.?
Old 07-05-2009, 08:30 AM
Big Mule Big Mule is offline
I had the same problem not to long ago. My problem ended up being the Check valves in the HPOS. The tech said he replaced the IPC and IPR valves as well.
Old 07-05-2009, 08:48 AM
Evil Eye Evil Eye is offline
Slacker Mod
Sounds like the vanes on your turbo are sticking. Pull the turbo and clean the vanes.
Diesel Technician Society
Old 07-06-2009, 05:15 PM
dill dill is offline
i have same problem, very noticeable with turbo turned off. I think the problem is low hpop pressure. when it does it pressure doesnt go above 2000.
