What's a 4C3Z9G489AARM? - Ford Powerstroke Diesel Forum
Old 06-27-2009, 09:11 AM
I had some work done on mine truck.
Code P0299. Removed turbo and replaced CHRA.
I'm just curious, also had the drain tube replaced with the newer larger one.
Thanks,
Old 06-27-2009, 12:33 PM
I believe it is the Turbo's "Center Housing and Rotating Assembly".
Replacing it is described in:
6.0L TURBOCHARGER CARBON DEPOSIT TSB 08-16-13.
If you want a copy of the TSB, I can send you one.
Old 06-27-2009, 09:08 PM
Hey Bismic! Hope everything's good with you. I was hoping you would find me on this. Any info would be great. I'm hitting about 26-29 psi on the boost with the stock tune when I'm hammering down. Before, I couldn't get over 24-25 psi.
I also had the 6C3Z9T515A tube assembly installed.
Thanks again! I just noticed that you have the ravelco. How do you like it? I can't find a local one in my area. Where did you put the plug at?
