What do you recommend?
I have to rebuild or replace the turbo on my 03. I do realize aftermarket turbo's are more money but I don't want to spend a ton of money because it is stock and plan on leaving it stock. Is there a aftermarket turbo out there and were would It buy from that is a better design then the original turbo so I don't have to replace it down the road? My truck only has 60,000 mi on it and I have been told I will most likely have problems again with the factory turbo down the road.
DP magazine just did an article on the 6.0 probs, they recomended using an 07 turbo, something about an intertnal groove for buildup..........
That turbo should be under the 100,000 mile warranty. Not sure if there is a time limit though.
I'll check out the article-thanks.. Keep'em coming. Any good info is appreciated. |
07 Turbo ? really never heard that before. If you not looking to spend too much money, send off your turbo to industrial Injection they can modify your VGT just above stock nothing huge but a little I believe its only 1400. Heres the link..
6.0L Turbochargers |
The turbo is under warranty(Oops! Just realized it's a 2003. The warranty is probably expired in 2008.). Just had the guts on mine replace as well as the larger drain tube from the turbo.
Are the vanes sticking or what's going on?
Where do you live? |
I live in Marquette MI-way up north. I love this site. There aren't much for ford dealers up here, I have learned alot about my 6.0 on this site.
The vanes are sticking-the turbo is barking all the time and the egr senser is bad. When its not barking its a rocket- apparently its creating alot of boost but not until the rpm's get up there. I have had my 03 for a few years but just drove it, never had to work on it untiul now, so I didn't know a hole lot about the 6.0 until my recent problems. After my first post I did alot of reading and talked to some good mechanics on the 6.0 and I am going to do what Pipewelder71 did plus go with the egr delete kit and hope for the best in the future. At first I was thinking about going with a aftermarket turbo but after I priced them, I'm not willing to pay 3,000 when the druck is only driven a couple months of the years-but if I had the extra money I would. Am I going in the right diection? Aaron |
