stacks - Ford Powerstroke Diesel Forum
Old 06-23-2009, 02:21 PM
stacks
What do all you guys do that have stacks open on the top when it rains or snows
Old 06-23-2009, 02:28 PM
Super Duper Duty
i havent had mine on in the winter but in the rain i dont cover them. a lot of water has to get in the to go up the dp and cause trouble
Old 06-23-2009, 02:34 PM
I've heard that when they get a bunch of water or snow in them the heat and liquid dissolves a bunch of soot in the pipes and then the pipes $hit all over your bed and trailer, making a huge mess.
Kinda makes me want hinged stacks. That would be so cool
Old 06-23-2009, 02:38 PM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
we use 5 gallon buckets over our big trucks cause we have had issues with the rusting out before
Old 06-23-2009, 02:39 PM
I think if you went to the lowest point of the stacks and drill a small hole in the bottom the water would drain.
Old 06-23-2009, 02:41 PM
Thats the most common thing amongst most guys with stacks that get alot of rain, all you have to do is just drill a really tiny hole in the bottom of your 90* that goes up into your bed
Old 06-23-2009, 02:49 PM
Shaking the Bush Boss
I dont cover mine, but it is parked under shelter. If I'm out somewhere and get cought in the rain....I dont worry about it. I have started putting rags held on with zip ties on the stacks after washing my truck. That way no soot gets on the truck. It dosent really make a mess in the rain....the rain washes it off.
Old 06-23-2009, 02:51 PM
stack flaps?
Old 06-23-2009, 02:53 PM
alright thats what iwas wondering i wasnt worried about it going up the the down pipe tho! haha just figured it would rust the 90 corners out eventually and wondered what you guys did to prevent that a small hole sounds right but in montana it snows alot haha i dont think i hole will help that
Old 06-23-2009, 03:52 PM
I've been around 18-wheelers my whole life and we never done anything to protect against rain or snow. The only negative I can see is eventual rust on the inside, but that will happen regardless.
