Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
  #11 (permalink)
Old 06-27-2009, 08:16 PM
swilson143 swilson143 is offline
Sorry for the delay. I'm confident it'll fit w/o the leveling kit. The point that it is closest to rubbing is lowest point of the fender liner (near the firewall)... and the front suspension compresses (like it would be w/o out the leveling spacer on the coil spring) it would actually move the axle forward... increasing the clearance to that low point on the fender liner.
I occasionally take my truck off road and I've never had my tires rub the fender liner... except one time when I had removed the liner and not gotten back into place properly. Once I heard it rub it was a super easy fix.
  #12 (permalink)
Old 06-29-2009, 11:27 AM
mavdog5p mavdog5p is offline
Will 305 65 18's fit on a stock F350?
  #13 (permalink)
Old 06-29-2009, 11:57 AM
No way to say with absolutely certainty until you talk to someone already running that combo... but my guess is yeah.
The first time I put the 305/70R17's on my truck I was concerned about fitment issues... my tire shop told me not to worry, that if there was any issue they'd pull them right back off and get me a size that did fit. Find yourself a friendly local shop to take the risk out of trying a larger size.
  #14 (permalink)
Old 06-29-2009, 03:58 PM
NIT2WN NIT2WN is offline
I was told not to go wider than a 70 series tire because of how narrow the rims are. I'm planning on some BFG Mud Terrains in a 285/70/17 when mine finally wear out. Like Swilson 143 said, find a friendly tire shop and try them on.
  #15 (permalink)
Old 06-29-2009, 09:33 PM
70 refers to the height. The first number is the width (285, 305, etc)... then the next number is the height, but in the form of a percentage if I remember right. So if your tire is a 285/70, then the width is 285, and the height is 70% of 285. I'm sure someone will correct me if I explained it wrong.
  #16 (permalink)
Old 06-29-2009, 09:51 PM
Will a 12.50 size tire fit in a stock 18" wheel?
  #17 (permalink)
Old 06-30-2009, 05:26 PM
You're probably correct. I'm just wanting to go a little wider and taller. I would like to take a little edge off of the 3.73's and get a little more highway speed with less rpm. Mostly, I'm trying to avoid buying rims.
  #18 (permalink)
Old 07-03-2009, 11:17 PM
Redneck47441 Redneck47441 is offline
If you want to you can buy one of those 2" leveling kits of eBay the aluminum spacer for like $45 Ive it now for 3yrs still going good lots of towing anyways I have 35x13.00x18's on my truck with that setup and no rub!
