Punching it to speed - Ford Powerstroke Diesel Forum
Fuel Price Area Discussions A place to discuss the fuel prices in your areas.
post #1 of 2 Old 06-03-2013, 08:13 PM Thread Starter
PowerGriz's Avatar
Hey,
So I watch my mpg like most people do when they buy a new rig. I've read a lot about some terrible mpg in a 6.0.
I don't really drive city, just country driving. I have the EGR delete done, other than that, its stock with 120k on it.
So I get 17-20 for a full tank all around. I was getting 15ish to 18, but then I found if I get on it to about 3300 RPM's until I reach cruising speed, then just maintain it, it just does so much better. Letting it idle up to speed basically is garbage MPG, like 14 getting up to 70 and the way it goes through the gear is painfully slow and bad MPG.
I drive 70mph on 2 lane highways in mountains, lots of passes, up down, curvy. These things coast like no other, mine just seems to coast so easy compared to my old truck. So once up to speed, it just seems to maintain well vs a slow start..
IDK...just 1 mans opinion.
2006 6.0 PSD 4x4 CCSB Lariat
Ranch hand bumper, EGR delete, sinister coolant filter, blue spring kit, new oil cooler,
PowerGriz is offline
post #2 of 2 Old 06-03-2013, 08:59 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It makes sense, you load it going all the way up to "cruising" speed, if you load it fast it shouldn't burn much more as opposed to loading it slow, since it's not under load as long it would use less, good thoughts tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
