'02 Explorer oil question, 10w-30 ok? calls for 5w-30 - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 04-21-2009, 10:26 PM
I, 1, 2, 1/2, 6
My girlfriend has an '02 Ford Explorer with the 4.0L V6. The manual calls for 5 quarts of 5w-30. I had an S-10 blazer before i had my PSD and I bought the oil to do the next oil change for it ahead of time. I have 5 quarts of Castrol Syntec 10w-30 sitting un-used.
NOW, my question. Would I be ok using the 10w-30 or should I just go get the 5w-30?
It would be nice to be able to use the oil I have sitting around.
Thanks
Old 04-22-2009, 09:01 AM
I, 1, 2, 1/2, 6
anybody?
Old 04-22-2009, 09:07 AM
As long as the oil meets the API Certification that Ford calls for, I don't think you will have any issues. With it being synthetic oil, it will probably have close to the same cold pour point as the 5W30 conventional.
Old 04-22-2009, 09:10 AM
I, 1, 2, 1/2, 6
I was thinking that it'd be alright too, it's only gonna be for this oil change. The next change I'll do the 5w-30 as called for. I just didnt want to have some oil i could be using just sitting there. Thanks man :thumbs:
Old 04-22-2009, 10:19 AM
Unless you live in an extreme northern place like Alaska or Minnesota, 10w30 should serve you just fine - especially a synthetic! This is especially true as we head into warmer weather.
Old 04-22-2009, 10:38 AM
Cynic
There will be no noticeable difference in 5w and 10w in warmer weather.
Old 04-22-2009, 10:43 AM
wriott
Guest
Posts: n/a
i run 10w in my 02 explorer, no problems after 100,000+ miles
Old 04-22-2009, 12:59 PM
I, 1, 2, 1/2, 6
awesome, I just wanted multiple opinions. Thanks
Old 04-22-2009, 01:05 PM
the gas ford engine is goofy id stick with the 5w-30 had a ton of problems with my 99 5.4 f-250 gasser when the dealer told me to use 5W-20 and the book called for 5W-30 it was knocking like hell
Old 04-24-2009, 05:53 PM
5.0 1996 EXPLORER 10W 30 IN WINTER 10W 40 IN SUMMER in mine.
JER-1
