| Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!! |
351 head bolt torq specs
351 head bolt torq specs need to know what final torq specs are on stock head bolts i have the order and first 2 then has blank as to third and final time
say 35 lb the 50 lb thanks Matt |
1993-1997 351 are - (with bolts died and holes tapped and clean, no oil) step 1- 85 ft.lbs, step 2 - 95 ft lbs and step three 105-112 ft lbs. If you oil the blots, take 10% off the torque values.
Jim |
I wouldn't oil the bolts, I would use moly lube, then torque to normal values. Run engine with normal break in procedures. Then re-torque to final just to be safe.
i found another says 85 lbs max engine is a 1978 Matt |
