Thud, Clunk, Pop - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 01-24-2009, 02:33 PM
Thud, Clunk, Pop
Well the 88 has a noise that I can't seem to find. I makes a thud, clunk, popping noise when I pull into a drive approach or when the frame twist good. Sometimes it does it and sometimes not. If I take it easy like crawling it won't make the noise but if I just go at a normal rate it will make the noise. It is coming from the drivers side somewere in the cab. I can feel it in the pedals and sometimes in the seat. What is giong on here? Anyone know were this noise is coming from?
Old 02-05-2009, 06:30 PM
check your body mount bolts and ball joints. any suspension bushings that look suspect could cause that type of noise too.
Old 02-05-2009, 06:33 PM
+1 ball joints, they can make strange sounds.
