Rear end grinding - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 01-12-2009, 06:00 AM
Infidel
Rear end grinding
Howdy all,
I towed a stock trailer with a quarter horse in it over the weekend. Total trip as approx 250 miles. Half way into my trip I started hearing a grinding sound when I would turn. Seems to be more prevalent in a right hand turn. I would also hear it when I started moving from a standstill going straight forward.
I am planning on change the fluid, I am concerned that I might have a more serious issue going on. So do I change the fluid and see if that resolves the problem, or do I take it in and have a mechanic look at it?
99 F-150 5.7L 2WD Ext Cab 227,000 miles, no mods.
Thanks,
Craig
Old 01-20-2009, 11:40 PM
Re: Rear end grinding
I think it will be good to take it to mechanic and other automobile professionals. If you change the liquid of yourself you and i don't know what will happen. So take it to the mechanic and follow his advice.
Chief Enterprises | America's provider of Bosch Relays, Solenoids, Connectors, and Diodes
Old 01-21-2009, 08:24 AM
I gonna say the pinion bearing is going, my Roush sounded like that, except it went at 14,000 miles.
Old 01-21-2009, 08:27 AM
Infidel
I had one guy say that it was the clutch packs for the limited slip. Does this sound right? I don't know squat about rearends (Choctaw is the real expert here).
Craig
Old 01-21-2009, 08:29 AM
rdc rdc is offline
Grumpy Non-Socialist
Craig,
Do I have to tell you what came to mind when I read the title of this thread?
Old 01-21-2009, 08:34 AM
COLLEGE KID
Send a message via AIM to lifewitlooie
Old 01-21-2009, 02:47 PM
Craig
It may be those also, sounds like you'll need a rearend rebuilt.
Old 01-21-2009, 02:59 PM
this sounds like either carrier bearing or axle bearings something like that but i highly doubt changing the fluid will do anything just take it in they are not hard to fix but if u dont know what your doing then just take it in
Old 01-21-2009, 03:15 PM
Cynic
Post what the tag says. It should be bolted to the rear cover.
Old 01-21-2009, 03:20 PM
Rear end noise
If it were mine, I would pull the rear diff cover and have a look. I have seen a lot of ford rear ends have issues with the ring gear bolts backing out. It doesn't cost you anything more than some silicone and gear oil. Just my .02
