F-150 with 5.4l questions - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
 1Likes
post #1 of 23 Old 03-07-2014, 04:49 PM Thread Starter
MacDougall's Avatar
well im looking at getting rid of my 6.0 and getting a newer F-150, a 2009 or newer. im not in need of the diesel anymore and there is no point in paying the extra maintenance and fuel for a diesel. but I had a couple questions on the 5.4l that the newer fords come with. are there any known major problems? and what is there average life span miles wise? and what about the truck it self? any problems? all the ones im looking at are 2009 - 2013 so.
Mike:
2003 F250 CCSB 4X4, 6.0L powerstroke.
-Sinister coolant filter
-Upgraded blue spring
-5" diamond eye exhaust W/ 6" tip
-Edge CS
-SCT tuner W/ vivians looney tune
MacDougall is offline
post #2 of 23 Old 03-07-2014, 05:06 PM
tdm156's Avatar
if you go with the newer ones in think you are beyond the spark plug issue....I had an 07 with the two piece plugs and you want to make sure if you go that way that they have been changed. cannot speak about the newer ones myself
tdm156 is offline
post #3 of 23 Old 03-07-2014, 05:09 PM
Chug-a-lug!!!
colberjs's Avatar
Quoted: 11 Post(s)
I would seriously look into the EcoBoost. I drove one for a couple of days while my PSD was at the body shop and was quite impressed. You will get better mileage and probably have as much or more power.
Jesse
2011 F-250 Fx4 CrewCab Short Bed
Bone Stock............Or Is It?
colberjs is offline
post #4 of 23 Old 03-07-2014, 05:21 PM
kcoyner's Avatar
Quoted: 67 Post(s)
I had a 2003 E250 with a 5.4 and did have the spark plug issue. Shortly after is was fixed, it's dropped a cylinder. Lots of dead 5.4s from that era. Can't say about the newer ones.
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
post #5 of 23 Old 03-07-2014, 05:24 PM Thread Starter
MacDougall's Avatar
ive looked at the eco boosts and my uncle has a 2012 platinum eco boost that is a beautiful truck and has a lot of power, but all the trucks im finding with what I want are the 5.4 or 5.0l ive found a few XLT eco boosts in my price range but I was wanting lariat or king ranch so
Mike:
-Edge CS
post #6 of 23 Old 03-07-2014, 05:27 PM
theplumbingmedic's Avatar
My cousin has a 2012 with an eco boost and he loves it. He says mileage sucks when pulling but he only does that a few times a year other than that mileage and power are great. FYI
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #7 of 23 Old 03-07-2014, 05:32 PM
05 was the bad year for that. Stay away lol
03 f350 is offline
post #8 of 23 Old 03-07-2014, 05:56 PM
RedneckYankee's Avatar
Shop truck was an 09 with 5.4. Injectors constantly fouled, had two engine harnesses put in it, two throttle position sensors. When it ran good it was fine but it would constantly have a miss, ruff idle, and when throttle position sensor would act up the truck would surge with no warning. Ran into a concrete pillar with out warning.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #9 of 23 Old 03-08-2014, 03:50 AM
Tim1216's Avatar
Quoted: 14 Post(s)
I had on 04 5.4, luckily when I bought it the previous owner replaced the spark plugs and the exhaust manifolds bc the studs break. It had 120k miles when I sold it and got my 6.0, no major issues. Just stupid little stuff like sensors and stuff previously mentioned. If you're goin with a newer truck I would definitely get a 5.0 or ecoboost. Two of my close buddies have 5.0s and they love them and my uncle has an ecoboost and loves his, it's impressive how much they haul azz
Sent from AutoGuide.com App
2011 F350 CCSB Lariat Ultimate
H&S Mini Maxx w/ GH Tuning, No Limit Stake 2 Intake, No Limit Full EGR Delet, Flo Pro 5" Straight Pipe
07 F250 Outlaw-SOLD
Semper fi
Tim1216 is offline
post #10 of 23 Old 03-08-2014, 10:29 AM
Zejokee's Avatar
Quoted: 5 Post(s)
Drove a 08 250 with the 5.4 for work. Had a 8ft utility bed that was fully loaded. Drove that thing back and forth between KC and NY and it drove great. Had plenty of power, for hauling what ever I wanted in the bed and towed great too. Never had any problems out of the engine. The snow contractor here uses a 04 350 CC LB with a 5.4. Plows with a 9ft blade and has a salt hopper on a flat bed behind the cab. They have 250,xxx miles on the engine and it runs great. Terrible MPG and the truck is rusted out but the engine is still going.
2011 F-250 SD Crew Cab FX4 Lariat 6.7 PSD SRW, H&S Mini Maxx, DPF delete, EGR delete, 5'' straight piped. Leveled.
04 F-350 SD Crew Cab FX4 Lariat 6.0 PSD SRW Stolen
Zejokee is offline
