My blinker is flashing quickly? - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 10-20-2008, 07:19 PM
Question My blinker is flashing quickly?
I was making a right turn and my indicator was blinking VERY quickly. I checked the bulb, it was good. So I'm wondering where the blinker fluid fill is. Anyone done this? Here's what I picked up.
Any help would be greatly appreciated
Old 10-20-2008, 07:20 PM
thats pretty decent stuff but this is better.this what we use in our race car
Old 10-20-2008, 07:21 PM
ehhhhh joke right? elbow grease, headlight fluid? im just not gonna take this one seriously har har but maybe im wrong but heres a free bump
Old 10-20-2008, 07:22 PM
Front or rear? This is VERY important! Don't mix 'em or your hazard flashers won't work. And you got the wrong one, our rigs take the RBF800 dude, that stuff might work but they'll be dim.
Oh and the filler cap for that is under the hood near the 710 cap.
Old 10-20-2008, 07:23 PM
Don't forget to check your Muffler Bearings.
Muffler Bearing - $49.99 : KaleCoAuto, Hard to find automotive items!
thats not true. the resorvoir is located on the back of each headlight as they run seperate for each blinker.
Old 10-20-2008, 07:26 PM
Oh my bad, you're right. On a Chevy its a single cap but it splits in the filler neck, such a pain. I think that's why those running lights never work.
Old 10-20-2008, 07:27 PM
Not true either. If you are going to try and correct someone atleast do it with REAL information. The resorvoirs are vaccum operated by a high tensile johnson rod. Allowing the equal distribution of pressure among the lines and blinkers.
To the OP. Your problem might be caused by the change in the weather. Cold temperatures cause the johnson rod to shink and contract. Making it harder to pump the fluid evenly throughout the lines.
I hope this helps. If not, here is a free bump.
Originally Posted by !!!PainTrain!!! View Post
Thats the one I was gonna use
Old 10-20-2008, 07:29 PM
BOSS LEVEL
the fluid is color coded also. the green is summer and blue is winter.
isnt the reservoir next to the exhaust manifold?
