Aluminum body f150s - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
 6Likes
post #1 of 57 Old 01-16-2014, 03:45 PM Thread Starter
luke7.3's Avatar
Quoted: 24 Post(s)
Aluminum body f150s
I don't know if there is a thread about this already but what do you all think of the 2015 f150s containing 97% aluminum? I recently found out about this reading an article in our local newspaper. Do you guys think that it was a good move for Ford? I think it's kind of risky being the best seller in trucks for over 30 years. I also read that the engine would be slimmed down.
I think they shouldve worried about getting a powerstroke F150 instead of worrying about its weight. Chevy colorados are getting Duramax's and Nissans are getting Cummins so why doesn't Ford enter the diesel half ton world with an F150 Powerstroke?
Anyways, I think that the trucks will perform fine but I think it will kill the steel industry and maybe shift some people to the Ram 1500s with more steel.
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #2 of 57 Old 01-16-2014, 04:03 PM
Heavy_GD's Avatar
Quoted: 1429 Post(s)
Feedback Score: 3 reviews
My first thought is that aluminum doesnt rust... and none of those competitors have done a diesel yet, just talk.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #3 of 57 Old 01-16-2014, 04:07 PM Thread Starter
luke7.3's Avatar
Quoted: 24 Post(s)
The 2015 Titan will have an available Cummins as well as the 2015 Colorado will have an available Duramax. No talk at all about a diesel F150 though. Dodge already has the ecodiesel available in their 2014 jeeps and ram 1500s
And I agree with the rust free part but the integrity and the body not being as dent proof is a worry to me.
sparkplug? and Heavy_GD like this.
Luke
luke7.3 is offline
post #4 of 57 Old 01-17-2014, 06:11 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Not even steel is dent proof, it's a chance to try something new honestly, ford put out the ecoboost, and the SD is the number 1 selling 3/4 and 1 ton platform last I checked, they don't need a diesel f150 simply because they don't need to put in the effort to waist money like the competitors to keep up with themselves, I like the aluminum body idea, hell my 11 crew cab 5.5' bed 4x4 f150 ways a good 2k more then my 95 cclb drw diesel 1ton. Explain why a 1/2 ton needs to be that heavy? weight reduction is also a great way to improve fuel economy
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 57 Old 01-17-2014, 06:23 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I give the credit for having the Kahones to try this. Aluminum is lighter and stronger than steel. If this all works out and I cant see were it wont, it will only be a matter of time before the 250/350 is aluminum as well.
But I also agree with the op. They are late to the diesel 1/2 ton party.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 57 Old 01-17-2014, 11:35 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
They had a diesel ranger what 30 years ago just didn't do well, if dodge sales go up because of the diesel option I'm sure ford 1/2 tons will get the same powerstrokes from the new van lines that are replacing the econoline series (mini box truck things I can't think of the name as I type )
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 57 Old 01-17-2014, 12:04 PM
jse51599's Avatar
I like the idea. Like stated before, no rust. Not sure how aluminum stands up to winter conditions with the salt, especially for you northerners...., but I'm sure Ford has done their research. As far as the 80's diesels, we know all too well how great they were in general.... I don't see them putting a diesel in an F-150 for the same reason the Ranger was discontinued.... by the time you would option one out you could step up to a SD for probably not too much money, and have twice the capability....
6637, Diamond Eye Turbo Back, Riffraff Billet Intake Plenums and Intercooler Boots, WW2, Deleted EBPV
305 70 16 Toyo A/T IIs
Jim
jse51599 is offline
post #8 of 57 Old 01-17-2014, 12:09 PM
BigGreen06's Avatar
Quoted: 101 Post(s)
I watched a video of them debuting at Detroit, they said the chassis is still mostly steel its mainly the body that is all aluminum, they actually called it "Super Aluminum" said it was a lot stonger than the steel previously used. I was kinda upset when they said they are discontinuing the use of the 6.2 though.
They did say their New 2.7 Ecoboost V6 will out perform some of the bigger engines due to state of the art Turbo tech, so I am looking forward to those tests, though never thought I'd see an engine that small in a 1/2 ton.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #9 of 57 Old 01-17-2014, 12:38 PM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 111 Post(s)
I doubt they would make a F150 diesel for the fact that you can just get a F250 short bed and it is practically the samething just a different look. Putting a diesel in a F150 would be to much for what it's worth. The only F150 I can see having a diesel is the Raptor for the fact it has the heavier suspension compared to the other editions. To put a 6.7 or make a whole new engine would most likely require a more heavier suspension and other things. Where as making a gas the only engine, alot doesn't need to be changed for each edition and year.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 Pro Comp lift on 315/75r16 Fierce M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #10 of 57 Old 01-17-2014, 05:40 PM Thread Starter
luke7.3's Avatar
Quoted: 24 Post(s)
Yes, Ford has some balls for entering the nearly 100% aluminum group like that Tesla electric supercar thing, but like I said, its a risk. If the payloads and towing ratings are the same or greater, I think it's a hell of an advancement in aluminum technology. I think that this will bring the full size crew cabs back down to the 5,000 lb range. And Kris, I think it's unbelievable that these half tons weigh more than our old obs powerstrokes.
As for the diesel part, the reason I think Ford should get a diesel is because of the fuel economy numbers the Ram Ecodiesel is showing. 28-30 mpg highway is unbelievable in any truck these days. Also, the longevity of the engine. I think they should drop in the 4.something liter 6 cylinder powerstrokes they used to put in cabovers. That's my two cents.
Good for Ford. I hope that they stay number one. It's all my family has ever owned and it's all I'll ever own. Who knows, maybe I'll have to go to the bank and see if I can take one home when they release them.
Luke
luke7.3 is offline
