12 Valve in an F150? - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 2 Old 12-30-2013, 05:17 AM Thread Starter
jmoney330's Avatar
Hey y'all how's it going?
Well since I just recently sold my 05 6.0 problem child, i'm now in the market for a new ride.
Browsing the local CL today I found an honestly pretty bad-*** F150 12-valve, NV4500 cummins swap (other than it's step-side and that ugly green color, no offense )
Anyway it's got 8 lug axels and its lifted up quite a bit and this and that. My only concern is the weight of the 12 valve an issue do you guys think?
And yes, of course it's got the dodge tow mirrors. And yes, they, of course, are flipped up
Sold
2005 F250 SD SCLB. OEM Gaskets, ARP HeadStuds, EGR Delete. BulletProof Diesel 6-phase 58v FICM. Sinister Coolant Filter. STC Fitting, Blue Spring, Stand Pipes and Dummy Plugs. 35" Cooper Discovers on Ford Factory Rims. GlowShift Max Tow gauges. 3" Lift. SCT Livewire (Canned Tunes at the moment, soon to be Looney Tuned). Kensun 6000k Headlights & Foglights. Zoodad Mod. Problem child
jmoney330 is offline
post #2 of 2 Old 12-30-2013, 07:57 AM
Sam Burton's Avatar
If everything was done properly the weight shouldn't be an issue.
post a link so we can check it out.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
