on my way to buying a 1990 F250 - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 3 Old 12-30-2013, 12:04 AM Thread Starter
well, my trusty at home commuter decided it didn't want the #3 connecting rod any more and gave it back. been ignoring a rod knock for quite some time and finally the isuzu had enough and gave up the ghost. been looking for a new truck for a couple weeks and found a 1990 2wd F250 with a 460. has almost 99,000 miles on it and they were only asking 3,000. went and took a look at it today and this thing is gorgeous! exterior is decent, lots of scratches and little dings, only two pretty good sized dents but other than than nice straight body. the interior is literally immaculate. other than one small crack on the passenger side on the side of the dash, it looks like the day it came off the show room floor. only kickers, the AC doesn't work (either the compressor clutch is shot or the freyon leaked out) but still blows cold air, and the radio cuts out from time to time. might go and get a once over from a mechanic before i shell out the cash but thinking this might be a great truck! wish it was 4wd but beggars can't be choosers! hopefully my first non-diesel ford will be a good experience.
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
post #2 of 3 Old 01-14-2014, 08:14 PM
theforeman57's Avatar
Quoted: 4 Post(s)
Uh-uh. Trust me, there is something about 89-92 460 efis, imo.
We have a 89 shop truck/ plow truck with one that I just converted to carb. we went through 5 in tank pumps, three different computers, had the entire engine wiring harness checked by a reputable shop after we could not find anything wrong with it.
It would start, run great for 5 miles, then die. next time it would run for a week, but would die and not restart.
I would seriously look It over, just my two cents. btw, we never got better than 9mpg, however it does have lowish gears.
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #3 of 3 Old 01-14-2014, 08:23 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's a gas hog for sure, but they do have some balls, and sound mean with an exhaust, good luck tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
