I Screwed Up - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 8 Old 10-24-2013, 06:13 PM Thread Starter
I Screwed Up
Selling my 99 250 V-10. I decided to give the engine bay some cleaning.
Sprayed Purple Power all over, then hosed it down with the engine off.
I started the engine and finished rinsing off the grime.
I used a leaf blower to dry it off with the engine running.
Now it doesn't run right.
It has a miss at idle and stumbles in gear at lower rpm.
Runs smoother at higher rpm above 3,000, but won't accelerate smoothly.
I drove it 40 miles on the hiway but no improvement.
Something got wet and wont dry itself out.
The air filter is dry.
Looking for ideas, don't want to pull every wire connection looking for water.
2013 F-350 Platinum 6.7 4X4 CC LB
2007 F-150 XLT 5.4 4X4 SC SB
1999 F-250 XLT V-10 4X4 CC LB
XR250R is offline
post #2 of 8 Old 10-24-2013, 06:24 PM
KillNThrill24's Avatar
IIRC.... You have COP's right? I'm more of a Mustang guy than a diesel guy in terms of knowledge so if I'm remembering right then it's probably an easy fix as I did the same thing with my mustang............. Pull your coils. I'd bet money you have water up underneath them in the spark plug chambers and it's causing your miss
EDIT: Yes I just double checked you do have COPs. Time to pull em! Get the vacuum ready!
2000 F350 Lariat CC LB, 00 Mustang GT, 01 turbo Cobra
KillNThrill24 is offline
post #3 of 8 Old 10-24-2013, 06:36 PM
late_99_PSD's Avatar
Quoted: 10 Post(s)
You definitely have water in the secondary system (high voltage spark.) You should be able to take off the coil packs and blow out the water with compressed air.
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #4 of 8 Old 10-24-2013, 07:17 PM Thread Starter
Thanks guys, I will get on that tomorrow.
Having flashbacks of when I replaced the plugs, the back ones are hard to reach. At least I got a place to start. Much appreciated.
This is another one of those times I wished I had left well enough alone.
After it all dried under the hood, it hardly looks any cleaner.
XR250R is offline
post #5 of 8 Old 10-24-2013, 10:08 PM Thread Starter
Well I couldn't relax tonite so I pulled 2 front coils on one side and 1 on the other side. They were totally dry, no moisture anywhere.
Wondering if I should keep going with this as it gets tougher as you work toward the firewall. Seems like the front ones would have got the most water exposure.
I got it in the heated garage with a fan under the hood for the night.
XR250R is offline
post #6 of 8 Old 10-25-2013, 05:16 AM
mudfuel06's Avatar
I would pull all of the COP's and let it dry out.
2007 F250 Lariat Outlaw Edition-High Idle Mod,Sinister Coolant Filter
2001 Coachmen Royal 326RLS
2010 EB Expedition EL-The Wifey's
mudfuel06 is offline
post #7 of 8 Old 10-25-2013, 01:21 PM Thread Starter
Today I pulled all 10 coils.
2 back ones on the driver's side were wet.
I blew them all out with compressed air, then gave them a roasting with a hair dryer. Pulled the rubber boots off the leads.
I'll leave it all apart for a day to make sure everything is totally dry.
XR250R is offline
post #8 of 8 Old 10-28-2013, 06:31 PM Thread Starter
Thumbs up Problem Fixed
Just finished putting it all back together.
Sounds like it should now, nice and smooth, no problems.
Thanks again for the advice.
XR250R is offline
