351w ignition timing question - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 2 Old 10-16-2013, 07:02 PM Thread Starter
1993 351w. trying to set ignition timing but I am unsure of where on the timing tab I should be lining up the TDC mark on the balancer. There is that sight hole and the edge that says "time" and in between a semi circle cut out. All three look like good suspects for lining up the mark.
I think it is the "sight hole" but unsure. I say that because today I found TDC on the #1 piston and the mark was lined up in the middle of that sight hole.
Is that where the timing mark "should" be? I haven't tried to fire it up yet because I need to go to bed. First time I have fired the engine since Ive owned the truck so I am anxious to get it going!
Thank you very much gents!!
Chuck Norris once visited the Virgin Islands, they are now known, simply as, The Islands
sixoh is offline
post #2 of 2 Old 10-21-2013, 07:49 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
On my 95 there was a pointer that hung over the crank, and timing was supposed to be at 10* before TDC iirc, shined a timing light while she was spinning and it was pretty obvious, but yours isn't running, I beleive there was a 0 and some tallies went in incriments of 5 iirc, good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
