351 Windsor valve "adjustment" - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 3 Old 10-05-2013, 09:07 PM Thread Starter
Hey all. Just replaced head gaskets on a 1993 150, 351w. I read that to adjust the valves (hydraulic lifters), torque them to the specified torque (20#'s) regardless of the engine/valve position. This doesn't make sense but is it right? I am anxious to get this truck going I appreciate all help. Thank you!
Chuck Norris once visited the Virgin Islands, they are now known, simply as, The Islands
sixoh is offline
post #2 of 3 Old 10-06-2013, 09:59 AM
Sam Burton's Avatar
yeah the late model small blocks use a non adjustable pedestal rocker set up, if they are a stock head just bolt them on and go.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #3 of 3 Old 10-06-2013, 12:37 PM Thread Starter
Great! Much easier/faster than rotating the engine 90 every time. Thank you very much
sixoh is offline
