2011 E150 van, cig lighter question... - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 11 Old 05-31-2013, 03:22 AM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
my work van is a e150 5.4. i have 2 power points on the dash in it. I have a sirius radio that you can pause and it will store up to 1.75 hours of that station that youre on's programming. so say i get out on a call, and want to hear the game. I pause the radio and i can pick right back up whwere i paused it(baring i was not there more than an hour and 45 mins) and listen all the way back up to real time. or, i can go back and listen to the songs that station played while i was out of the vehicle. kinda like a dvr for radio sorta.
anyhow, it works as long as you dont lose power to the radio. when I shut the vehicle down, all is good, radio stays on no probs. when i crank the vehicle back up, it cuts power to the cig. lighter for just a split second....long enough to reset my gps, sirius radio ect...and they have to start up fresh just like i just plugged them in.
I ran a fused hot lead from the battery and inside the cab, and then a ground and plugged sirius in there...still does the same exact thing...it loses power for a split second and then right back on again. Why does this do this?????
any other vehicle that Ive ever had that has a constant hot cigarrette lighter port never did this. does anyones newer models trucks cars do this? how can I stop it?
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 11 Old 06-01-2013, 06:49 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Bump?
Sent from AutoGuide.com App
Nick
"The Mistress"
post #3 of 11 Old 06-03-2013, 10:38 AM
mudfuel06's Avatar
My 08 cigarette lighter stays hot all the time. I don't know if the other power point does, but I've never noticed my phone flash at me when I'm charging it.
2007 F250 Lariat Outlaw Edition-High Idle Mod,Sinister Coolant Filter
2001 Coachmen Royal 326RLS
2010 EB Expedition EL-The Wifey's
mudfuel06 is offline
post #4 of 11 Old 06-03-2013, 04:59 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
No it stays hot when key is iff or if the truck us running, but when I crank it it looses power for just a split second enough to reset the sirius radio and the gps. I can also hear my phone beep and let me know its off charge. Then beep again tripling me its back charging.
This is with the factory cig lighter, or the straight from the battery hot wire I ran. Its really weird.
Nick
"The Mistress"
post #5 of 11 Old 06-03-2013, 05:08 PM
ZMANN's Avatar
Quoted: 1670 Post(s)
i think your voltage is dropping low enough that the device meets it's low threshold and turns off
there is no reason a straight wire from the positive would go off at all IMHO
and this may be an early warning about the condition of the batteries
might try an individual load test for them
We Miss you Ronnie
ZMANN is offline
post #6 of 11 Old 06-03-2013, 05:11 PM
ZMANN's Avatar
and being it's a Gasser LOL
just read that factoid
I would suspect that one Battery
We Miss you Ronnie
ZMANN is offline
post #7 of 11 Old 06-03-2013, 05:13 PM
ZMANN's Avatar
one question
on the hot lead where did u hook it up for the sirius ?
to the cig lighter along with the OEM wire ?
We Miss you Ronnie
ZMANN is offline
post #8 of 11 Old 06-03-2013, 07:42 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
No, I ran a wire direct from the battery inside the cab area. And hooked it directly up to a external 3 port cig lighter plug thing.
Nick
"The Mistress"
post #9 of 11 Old 06-04-2013, 06:45 AM
mudfuel06's Avatar
Maybe try a higher cranking amp battery? As said above, maybe when it's pulling the juice to crank the van, it hits the limit for the device to shut itself down.
post #10 of 11 Old 06-04-2013, 02:05 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Possibly. But im not going to buy another battery because it's a my companies work vehicle. Ill just have to deal with it I guess
Nick
"The Mistress"
