05 F250 5.4 SCSB, from parts to driving. - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 29 Old 05-23-2013, 09:04 PM Thread Starter
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Well here is the deal; Back in March 2013 I bought an all white 2005 F-250 XL Super-Cab Short-Bed 2wd A/T with a 5.4 for the 2005+ brake hardware to swap under my 2000 Excursion.
A man had it advertised on Craigslist with 311308 miles and a bad motor. It was still sitting at the shop when I bought it for $1700. I paid $75 to have it towed to my shop where I found a bad cyl 6 injector. I stuck a 21# injector in it out of a 01 P71, and chainged the oil. It turns out to be not to bad of a truck and the wife wants to keep it. So now I have in it:
$1700= Initial cost.
$75= towing.
$25= oil&filter.
$20= tailgate strikers (4-?-13) Cairo Craigslist.
Tinted front windows (4-29-13)
Stake pocket covers X2 (5-2-13)
$500=2008 Tailgate (5-2-13)
$599=Stainless 6" stacks kit (5-6-13) e-bay.
$1145=2004 H-D 18" wheels (5-7-13) e-bay.
$26= L hinge/roller, bolts, backing plate, and 1 cable bolt (5-10-13) Tall. Ford.
$51= 99-07 power Paddle mirrors (5-16-13) BucOff.
Left tail-light (5-21-13)
40-20-40 grey vinyl seats (5-24-13)
2000 Excursion front brakes (6-4-13)
2000 F350 7.3 L-code coil springs (6-4-13)
$1330 295-65-18 Goodyear Wrangler Dura-track X4 (6-4-13) local tire store.
$150 2013 painted rear bumper (6-10-13)
$50 sliding and tinted rear window (6-10-13)
$41 2007 KR 6-disk CD player (7-15-13) powerstroke.org, Humvette
$26= Left Axle seal (7-?-13) local parts store = installed 7-23-13
$12= Shock mount right rear (7-24-13) e-bay
$29= H-D transponder blank (8-7-13) e-bay
$2 = cut key (8-?-13) Firehouse
$59= 2" front spring spacers (8-13-13) e-bay
$10,100=2005 F250 SCSB V10 (1-15-14)(77k) Orange Park Ford in Jacksonville
$285=Transporting V10 F250 (1-15-14)
$140=Chrome tow hooks (1-17-14) e-bay
$17 = Chrome mirror covers (1-19-14) e-bay
$113=H-D floor mats (1-30-14) powerstroke.org, Kennyv
$31 = OEM Ford front mud flaps (1-30-14) e-bay.
$250= 2010 King Ranch tan/gold painted rear bumper (2-17-14) Valdosta Craigslist.
$98 = Integrated Trailer Brake Controller w/ pocket, & Master cylinder (2-17-14) powerstroke.org, broncomitch.
$257= 2008 Chrome/black rear bumper w/ sensor wholes (2-21-14) e-bay.
$437= 5-Star SCT tune: 87 performance, 87 Tow without 5th, 93 performance, 87 economy (2-24-14)(78k) Mike.
$61 = Case of 12 Motorcraft SP transmission fluid (2-26-13) TPH.
$305=Champion 7989 spark-plugs, Lisle 65600 extractor (3-5-14) O'Reilly's Quincy.
$47 = 10' of 2"x3" 3/16 tubing (3-?-14) Tall. Jone's welding.
$385=2001 Excursion 4L.30 rear-end (3-17-14) LKQ.
$120=2013 certer seat (3-24-13) e-bay.
$48= friction modifier & 3qts. gear oil (3-25-14) TPH.
$75= 1986 Bronco fuel sending unit (3-26-14) e-bay.
$150=plastic replacment 1988 Bronco fuel tank (3-26-14) e-bay.
$10= 5/16"X1-1/2" differential cover bolts (3-29-14) local parts store.
3/4" forward offset 3/8" lift blocks (3-29-14) Bradley.
$20= 1999 Diesel tank inlet pipe (4-6-14) powerstroke.org, ironmansd.
$35= 2006 master cyl. for ITBC (4-21-14) e-bay.
$95= 2004 4wd front shocks to use on rear (Monroe 34686) (4-23-14) local parts store.
$9 = EVAP hose & fittings (4-24-14) local parts store.
$194= 2005 Harley-Davidson bed decals (orange) 4-26-14/5-15-14) Tasca.
$43= Have dealer activate trailer brake controller (5-2-14) Marianna Ford.
$??= ? upper and lower ball joints (5-2-14) TPH.
$40= Front-end alinment (5-3-14) Marianna RoadMart.
$65= 96 Bronco front quad-shocks (6-6-13) TPH.
$61= 81,101mile oil change with 10-w30 Mobile-1 (6-12-14) Quincy Advance.
$560=EATON True-trac (6-13-14) Summit
$71= 05 Excursion Limited Grille (8-18-14) e-bay.
$34= 00-04 under-cab E-brake cable and equalizer (10-?-14) Tall. Ford.
$26= Reflective black "SUPER DUTY" tailgate inserts (11-11-14) e-bay.
$44= H-D brake pedal pad (11-11-14) e-bay.
$470=Front seats recovered in grey/black cloth (11-22-14) A-1 upholstery.
ID:	115777   Click image for larger version
ID:	115785   Click image for larger version
Name:	4-5-13 2005 suspension coming soon..jpg
2000 Excursion Limited 2wd Mods:Removed luggage rack, Running boards, Body molding, rear wiper,& 3rd seat. Chrome 05 bumper & hooks, grill & headlights, & 08 rear bumper. IAH delete, Banks elbow downpipe w/ 4" exh. 1.0 turbine, BD wastegate, ATS housing, AIS intake, SRP1.1, FRX, HPX, IHI up-pipes, 6.0 IC & trans cool, 160/30 inj, TS chip. Lowered 4", C-notch rear, Dream Beams, 05 brakes& G springs, 3.55 axle, 265-50-20"s on 06 KR's. Cloth 40/20/40 front seats w/ JL 10". Future plans: tweeters.
LSCR351 is offline
post #2 of 29 Old 05-23-2013, 09:10 PM Thread Starter
Quoted: 2 Post(s)
I will get y'all some more pics as it progresses.
I am also needing some stuff for it too, most of which I have posted in the wanted section here:
99-04 front ABS sensors.
08-09 center console front bracket.
05-07 H-D accelerator pedal.
08-14 Front door tweeters with harness.
08-14 Chrome rear bumper without B/U sensor holes.
LSCR351 is offline
post #3 of 29 Old 05-23-2013, 10:10 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Just 1 question, wtf made you wanna put stacks on a gasser?
Sweet score other than the $600 waist of stacks on a gas engine
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 29 Old 05-24-2013, 05:19 AM Thread Starter
Quoted: 2 Post(s)
I don't think stacks are Diesel specific. And I wouldn't call it a waist without hearing it. I have already cut the muffler off the 5.4 and it sounds mean. I think when I get the stacks on it will really scream! Personally I like the way they look, the same reason that anyone else has them.
LSCR351 is offline
post #5 of 29 Old 05-24-2013, 02:02 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
As long as you enjoy them bro
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 29 Old 07-03-2013, 06:54 PM Thread Starter
Quoted: 2 Post(s)
I have decided to get the truck painted. 2013 "UH" Tuxedo black, with 2003 "TK" Mineral gray on the bottom.
Right now the bed caps are off the bed, and the bed off the truck. While the bed is off I am also swapping the rear brakes over to the 99-04 style.
LSCR351 is offline
post #7 of 29 Old 07-03-2013, 07:42 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
What's the difference in the rear brakes? Thought they were sterling 10.50's and the exact same
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 29 Old 07-04-2013, 10:21 AM Thread Starter
Quoted: 2 Post(s)
Front & Rear track width changed in 2005.
The whole reason I bought this truck was to swap the wider 05+ brake parts (spindle, rotor, caliper, lines) onto my Excursion.
I have already swapped the front brake stuff between the trucks. Then I pulled everything (backing plates, hub, rotor, caliper, lines, cables) from the rear of this 05 and put on a stripped down 2010 3.55 rear I bought to go under the Excursion. Now I just need to put the 2000 Excursion rear-end back under this Pick-up.
LSCR351 is offline
post #9 of 29 Old 07-04-2013, 12:01 PM Thread Starter
Quoted: 2 Post(s)
Here is the reason for putting the 05+ brakes on my Excursion, so I could run 2006 King Ranch wheels.
ID:	134322   Click image for larger version
LSCR351 is offline
post #10 of 29 Old 07-23-2013, 06:11 PM Thread Starter
Quoted: 2 Post(s)
I got the Excursion rear-end under this pick-up today.
Now, this F250 project might get crazy tomorrow! I am thinking about shortening it 11". That will entail moving the axle forward 1", sliding the bed forward 1", and bobbing 10" off the rear.
LSCR351 is offline
