95-97 OBS gassers - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 7 Old 05-19-2013, 01:35 PM Thread Starter
95-97 OBS gassers
hey guys. im new to the site and I have been looking at getting into a older diesel to replace my worn out 97 dodge ram. ive come to relize that these old trucks sure hold some value and, for the most part, they are out of my price range. But i have found quite a few OBS f250/350 trucks with the 5.8 and 460 gasser motors thar are in decent shape. My needs for such a truck would be to tow my boat (6000lbs MAX) two or three times a year, some car trailer duty and just to Home Depot for things around the house. This truck wont be a daily driver, except during the heavy snow days, and it will sit most of the time until i need it. I had my heart set on a diesel, but they are looking out of my budget. So, school me on the 5.8(351) and 460 trucks!! Thanks again
Silverstang84 is offline
post #2 of 7 Old 05-19-2013, 02:26 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Well the first thing you need to know is 12mpg is the best you are gonna see ever out of either of those motors. Our trucks are just to damn heavy for that little 351. Now the 460 has all the power in the world but its just heavy on gas. Other than that they arent any different trucks than the diesels
Trucks and parts............
kanuck15 is offline
post #3 of 7 Old 05-19-2013, 02:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Worst economy, more often maintenance, but much cheaper overall when it's time for maintenance, but my f150 was bought to haul with and had a 351, has 354k miles and got around 8-10 mpg's, but very reliable, never had a 460 but never heard a bad thing about them
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 7 Old 05-19-2013, 03:15 PM Thread Starter
thanks for the input guys. anyonw else have any experience or opinions on these gas motors?
post #5 of 7 Old 05-19-2013, 03:20 PM
PowerStrokeBren's Avatar
I have a 96 F-350 with a dump box on it and it has a 460 been pretty good but it did need a new head put on cause it cracked.The truck has good power but the mpgs suck i get about 7 with a full load.
2000 F-350 7.3L Powerstroke
Autometer gauges
Banks 6 gun tuner
Banks Wastegate Actuator
ATS Turbo Housing with WW
K&N CAI
Magnaflow 4" turboback
2 1/2 Leveling kit
35" MT ATZ
PowerStrokeBren is offline
post #6 of 7 Old 08-28-2013, 05:01 PM
aswaff400's Avatar
fro 6,000 lb or less a couple times a year, a OBS F150 would probably do just fine. i pulled regularly with my '95 f150, i originally had a 302w in it but swapped in a 351w. i have done just about everything to my F150 and know it inside and out., now i have my '04 F250 for the daily towing
i work in a marina and have pulled many boats 2500 lbs to over 10K lbs with my f150, now i pull regularly over 14k lbs with my f250..
couple of boats ive towed, the only ones i got pics of.
my boat, 20 ft aquasport, around 3500 lbs loaded couldnt tell it was there.
my dads boat, 270 searay amberjack, estimating over 10,000 loaded.
a customer's boat i picked up for delivery, 270 searay sundancer
Aaron
'95 F150 XLT (SOLD), RCLB, 351w, 4-link SAS, 14 inch coilovers
'04 F250 Lariat 6.0L, FX4, CCSB, blue spring, egr delete, straight piped, CAT EC-1 coolant, sinister coolant filter, 2.5 inch leveled/lifted, RDS 60 gallon aux. tank, IDP tunes
a bunch of boats
aswaff400 is offline
post #7 of 7 Old 08-28-2013, 05:25 PM
alaskan155's Avatar
Quoted: 66 Post(s)
my 88 5.0 bronco(lightest combo) gets 15mpg max on the highway going 65, any more and around town it drops,
try to go with a f250/350 perferable(if 4wd)
the f150s are common to get 3.55 gears and the f250/351w is more than likely to get the 4.10s,
f150 for 96 is a oddball year as its obd2(maf)(bad if you have emissions, 94/95 are maf(best for upgrades) and 86-93 are speed density,
not sure on the f250s
f250/f350
my vote is for the 300 i6(rock solid motor) or the 460, skip the 351w(unless you want to build it up)
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
