'00 F150 Intake Coolant Leak - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 3 Old 05-04-2013, 08:45 AM Thread Starter
jesilvas's Avatar
Quoted: 2 Post(s)
My wifes 2000 F150 5.4 has the stupid intake coolant leak.
My question is, has anyone tackled this? I know I can do it but from reading it might be just the gasket, or the whole thing is cracked, or just a pinhole in a tube.
What should I do? Just get a new one or take it apart then decide what to do.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #2 of 3 Old 05-04-2013, 08:53 AM
Quoted: 2 Post(s)
00' has the plastic upper intake which is prone to failure, it's pretty common. Seems a lot of people use the Dorman replacement without issue. However if you can find one from a 99' 5.4 F150, it's aluminum and matches the ports on your 5.4's PI heads.
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #3 of 3 Old 05-04-2013, 11:04 AM Thread Starter
jesilvas's Avatar
Quoted: 2 Post(s)
Yea I knew the 99s were the good ones, but I'm sure good luck finding one.
http://www.amazon.com/Dorman-615-188-Upper-Intake-Manifold/dp/B003QVJ79K/ref=au_as_r?ie=UTF8&Make=Ford%7C54&Model=F-150%7C666&Year=2000%7C2000&carId=002&n=15684181&s=automotive&vehicleType=6I assume that's all I need?
Someone mentioned that they knew someone who uesd a Dorman in a 4.6 and wasn't good quality but who knows how accurate it was.
4R100, 2wd
330,000 + miles
jesilvas is offline
