Timing and carb adjustment, low vacuum, 400 Ford - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 3 Old 03-30-2013, 10:53 PM Thread Starter
HillbillyDeluxe39's Avatar
First the specs.
400 Ford .010/.010/.040
stock cam advanced 4* with roller timing chain
Edelbrock dual plane intake with 650 Holley vacuum secondarys electric choke
MSD 6AL with MSD mechanical advance distributor
Problems:
10 inches vacuum at idle @ 900-1000 RPM, wont run any lower, will randomly jump to 19 inches, was idling on primarys untill i lowered the floats.
Carb likes to backfire every once in a while on acceleration
running 20* initial timing, seems to like this the most
Truck is a 4 speed with larger tires and I dont have the power that I assume I should be getting from a 400, I adjusted my assumption a little for the larger tires, but the truck acts the same when I put the T-case in low.
Any help, advice or point and laugh is greatly appreciated.
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #2 of 3 Old 03-31-2013, 06:17 AM Thread Starter
Bump for the AM
2000 F250 CCSB 4x4
post #3 of 3 Old 03-31-2013, 07:03 PM Thread Starter
Bump for PM
2000 F250 CCSB 4x4
