300 I6 mods - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 46 Old 03-28-2013, 11:38 AM Thread Starter
97powerstroke turbo's Avatar
300 I6 mods
Its a Efi 92 version I know about fordsix.com but im looking for some diy stuff ideas
1996 Ford F-250 7.3 Powerstroke Diesel 286k fully built E4OD with lock up switch Stage 1.5 180cc injectors BDP fuel system Tony tunes economy daily tow street extreme smoke 3in dp-6in homemade stack traction bars fog lights and a ok sound system. Nuff fuel for 408hp just need that new gen2WW
1989 chevy 3500 with 92 gm replaced 6.5 with a 97 NV4500 banks sidewinder rv air filter and open exhaust. mileage is ur guess down right now needs a ops.
97powerstroke turbo is offline
post #2 of 46 Old 03-28-2013, 11:48 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
a K&N high flow reusable filter? diy wise not much to talk about
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #3 of 46 Old 03-28-2013, 12:33 PM
The Maddawg
maddawg89's Avatar
Quoted: 289 Post(s)
Feedback Score: 3 reviews
I have an 84 red block 300i6 and I can't find any either
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #4 of 46 Old 03-28-2013, 12:59 PM Thread Starter
Red block? Fill me in in this? Only red blocks I knew of was ih tractor Motors and 401 amc Motors that came from the ih in that color
post #5 of 46 Old 03-28-2013, 01:01 PM
The Maddawg
maddawg89's Avatar
Quoted: 289 Post(s)
I always thought the 300's were blue. Mine is red. I thought it was just painted but someone told me it was more like a HO deal. he was a pretty trusted, reputable mechanic so I went with it. I haven't researched it otherwise.
Bully Dog intake
post #6 of 46 Old 03-28-2013, 01:03 PM Thread Starter
Its a flareside stick 2wd im thinking running off the manifold into 2 inch exhaust and maybe fab up some duals for it.
Adding traction bars better intake and bump the timing up and some day turbo It. Hx 35 maybe with a tight housing on It?
post #7 of 46 Old 03-28-2013, 03:10 PM
The Maddawg
maddawg89's Avatar
Quoted: 289 Post(s)
Mines 84 sclb 2wd 4spd w/granny. Its a pulling hoss! But not much on speed. I got the exhaust manifold from a 90's to put on it cause it looks a little easier to make duals out of. Beyond puttin an intake on I'm not sure if there's much else. I took all the a/c out, the heat out, there's no power steering. I'm thinking on day maybe doing a bolt on supercharger on the a/c mount.... she's an ol beater so not really worth it..... Plus I have to many mods for the 99 7.3 to spend money on
Bully Dog intake
post #8 of 46 Old 03-28-2013, 03:14 PM
2500TD's Avatar
My dad used to have a set of headers for his 91. Not sure what kind of improvement was seen.
1996 F250 CCSB 2wd, 5 Inch exhaust, project underway
See my Build Here
2500TD is offline
post #9 of 46 Old 03-28-2013, 08:19 PM Thread Starter
I was told on Ford six and some other sites the Efi manifolds are perfect better then headers till a certain point. Ill probably keep the ac and all the nice stuff and since It a 5 speed should be good to go.
How do these things pull
A guy said It will outpull a 460 from a start both loaded with a bed of steel
post #10 of 46 Old 03-28-2013, 08:44 PM
The Maddawg
maddawg89's Avatar
Quoted: 289 Post(s)
How well? Lol sit down and let me explain.
I had a load of oaks that weighed close to 5,000 lbs that I pulled 55 something miles with some really big grades in the mix. I had to drop to third on most of them. All this was done before I rebuilt the head.
It pulled like a dream! It kept right behind dads 96 7.3 pulling about 7500 lbs.
The next week, I pulled the head. Did a water test and every valve was pouring water! Took it down to the shop and had it rebuilt. When I picked it up the guy was like "this truck wasn't running was it?" I was like well.....
The 300 is a hoss. I don't know that it will ever be a performance machine but if you want to tow its hour man. Just DO NOT let it get hot! Get a water temp gauge and don't let it go above 210*.
I really wish I had either the Clarke 5spd or the Mazda 5 in mine. I have the NP405. It's great no doubt for torque but I'm only getting 14-15mpg
Bully Dog intake
