F600 ? - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 2 Old 03-23-2013, 06:38 AM Thread Starter
bad_blue_oval's Avatar
F600 ?
I just bought a 68 F600 dump truck. It appears to be the factory "FT" engine but i want to know the engine size. Is there anyway to find out or do i need to pull a plug and measure the stroke?
02 F250
Full force stage 1's
FBD 5"strait pipe
DP Tuner
72 F100 4x4
bad_blue_oval is offline
post #2 of 2 Old 03-23-2013, 05:41 PM
How many Valve cover bolts?
2 bolts: 239/256/272/292/312 (produced from 1954 to 1964)
5 bolts: 332/352/360/361/390/391/406/410/427/428 (FE/FT engine)
6 bolts: 221/260/289/302/351W
7 bolts: 429/460
8 bolts: 351C/351M/400
The "352" casting appears on the outside of many (if not most) FE/FT engine blocks on the rear of the block (behind the flywheel), with no regard to the real displacement. So a "352" block could really be a 332, 352, 390, 410, etc.. Measuring bore and stroke is the best way to confirm the actual engine displacement.
99 F350 4x4 7.3 6 speed w/480K
02 F250 4x4 7.3 Auto w/490K
00 Excursion 4x4 V10 w/140K
F350none is offline
