V10 Exhaust Manifold Studs - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 24 Old 02-12-2013, 04:28 PM Thread Starter
I started the dreaded exhaust manifold stud replacment. Had 4 of 10 broken on the passanger side. Got the wheel well removed. Broke 1 stud, removed 1 and called it a night. Will pick up some dremel cutting wheels to remove the rest. They are rusted so bad the socket will not grab them. Wish me luck.
Not even looking at the driver side yet. It will just make me more discouraged.
99 F350 4x4 7.3 6 speed w/480K
02 F250 4x4 7.3 Auto w/490K
00 Excursion 4x4 V10 w/140K
F350none is offline
post #2 of 24 Old 02-12-2013, 04:29 PM
jesilvas's Avatar
Quoted: 2 Post(s)
How are you getting them out?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 24 Old 02-12-2013, 06:15 PM Thread Starter
The plan is cut the nuts off the ones to rusted to get a socket on and get the manifold out of the way. Next take vice grips and back them out. The ones broken flush with the block I plan on drilling a hole through the stud and spraying PB blaster behind them. I have to go to TX next week so they can soak while I am gone. Then I hope and ez out will back them out when I get back. I have read of people having good luck with that, but I have also read of some having bad luck. We shall see. The studs are known to break. Some say they are easy to drill and back out. I am hoping mine are.
F350none is offline
post #4 of 24 Old 02-15-2013, 01:12 PM Thread Starter
The saga continues. Have to cut the nuts off 5 of the studs on the passanger side. The 2 on top were easy. 3 on the bottom not so easy. Burt up the Dremel tool and stopped for Dinner. The 1200 to 1500 the dealer wanted is looking better everyday.
F350none is offline
post #5 of 24 Old 02-15-2013, 06:20 PM Thread Starter
Had to cut all but 2 nuts off. Was able to get 15 of the studs out of the head. 5 more to go tomorrow and the hard way. 4 are broken off at the head. One was rusted so small my stud remover would not grab it. Have to go get a right angle drill and some left handed bits in the morning then the saga will continue.
F350none is offline
post #6 of 24 Old 02-16-2013, 02:24 PM Thread Starter
This is my place to vent. Got 2 more studs out. Drilled holes in them and used e-z outs. Got 2 with holes drilled and soaking in PB Blaster. The last 1 well lets just say my aim was off. It was a pain to drill and about 3/4 of the way through it I went out the side of the stud into the head above the stud. No water came out so I did not hit anything Sprayed PB Blaster and let it soak too. I will soak the last 3 in more PB tomrrow then fly to Texas until Friday and let them soak. I think I can get 2 of the last 3 once they soak some but the one where I drilled into the head I am a little worried about. The wife is afraid I will blow it up and get a 7.3 Excursion. I am tempted at this point.
F350none is offline
post #7 of 24 Old 02-16-2013, 02:31 PM Thread Starter
Once I get the stud out where I drilled into the head does anyone know what I can fill the hole with and re-tap the hole? JB Weld? I'd like to find something I can inject just in the part that the hole is not supposed to be instead of filling the whole hole. Of would the best bet be heli-coil?
F350none is offline
post #8 of 24 Old 02-16-2013, 06:58 PM
jesilvas's Avatar
Quoted: 2 Post(s)
All I know is you have a lot of patience
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 24 Old 02-16-2013, 07:14 PM Thread Starter
Thats the problem. I don't. I have to work on it for a couple hours and walk away. The good thing is it has given me a good excuse to buy about $300 in new tools. Think I might need a plasma cutter to finish it. Wonder if the wife would agree.
F350none is offline
post #10 of 24 Old 02-22-2013, 01:59 PM Thread Starter
Got back from Texas. Got a new E-Z out and can't get it to grab the studs. I get it to the point where I think I am going to break it and it breaks lose from the stud. Any ideas how to get the crazy thing to not slip. It does it for all 3. I even tapped it with a hammer to get it to "seat" more. No luck.
F350none is offline
