2000 F150 5.4 Intermittent start - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 12-01-2012, 06:52 AM
My almost wife's truck doesn't want to start when cold. I think fuel pump, cause you can't hear it sometimes, and if you smack the tank, if will usually work.
Does anyone know where the harness plug is to test voltage at? On top of tank?
I figure I'll try a relay, and maybe that's it.
If not, has anyone replaced the pump?
Old 12-18-2012, 04:42 PM
could be the pump, probably not a relay. if it only does it cold or with weather change i would bet it is the fuel pump control module. they are mounted up above the spare tire and usually cause a hard start cold or long crank to start after driving in the rain or when temp changes a lot overnight.
worth a check before dropping the tank
Old 12-18-2012, 04:45 PM
Yeah I'd suspect the pump since you said you sometimes can't hear it.
Sent from my iPhone using AutoGuide.com Free App
Old 12-18-2012, 07:39 PM
Replaced the pump and relay, all is good. Easy job
I made my Samsung SGH-I997 send this.
Old 12-19-2012, 11:53 AM
Good deal
