5.4 triton horrible start up - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 2 Old 07-29-2012, 11:01 AM Thread Starter
Suzuki6mx's Avatar
100rpm!!
2002 F350 ext cab SRW 6 1/2' bed(mine)
2008 F350 CC DRW 8' bed(Dads)
2012 Reg Cab DRW Dump
1996 Reg Cab DRW Dump
1999 Reg Cab DRW Dump (After a year of sitting its back and running good)
2003 Ext Cab DRW 8' Utilty
Suzuki6mx is offline
post #2 of 2 Old 08-22-2012, 04:51 AM
Did you run a code test on it? Have you ever done a tune-up on it? Ford recommends a tune-up on those every 30k miles because of the chitty spark plugs, they are two piece and like to break off. Snapon makes an excellent tool to get them out but it is maybe a 3 hour process just getting the spark plugs out. That will definately help your problem and maybe check compression for a bad headgasket? Ford's aluminum 5.4 heads suck.
Owner/Founder of Georgia Diesel Power.
Current Sponsors: QuickTricks Automotive, Ray Paul Powdercoating, Ace Transmission, SoCalTrucks.com
Current Member Count: 16
TheRobenator is offline
