95 FORD 450 S/D - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 3 Old 06-28-2012, 12:15 AM Thread Starter
95 FORD 450 S/D
HI,My son has a 95 450 s/d with e40d here's the problem.
Today we were driving to a town 60mis away,when started getting on freeway and picking up speed the transmission started dropping in an out of gear,i had my son go to a lower gear got truck speed and up shifted manually when we got up to speed went into O/D and had no trouble from then on.
We have not had truck very long,so we thought maybe we need service trany
which is on our to do list,has anybody had this type of problem before,THANK'S
LOVEMYTRUCK is offline
post #2 of 3 Old 07-01-2012, 12:18 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I'm assuming it has a 460, but have you tried the shift sylenoid and check your u joints
Welcome to the org btw
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 07-03-2012, 06:45 AM Thread Starter
95 ford 450s/d
Thats one of the things we are looking at,one of the sites that makes a valve
that increases the line pressure says it will solve this problem and can be done when you change fluids&filters.
