1992 351w fuel problems - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 4 Old 01-29-2012, 10:57 AM Thread Starter
I recently swapped engines in my 92 Ford F-150 a 302 for a 351w. I have good fuel pressure at my fuel rail but im not getting fuel through the injectors. You can put fuel in the intake and it'll run until the fuel burns out. Any ideas what the problem could be?
metzy3204 is offline
post #2 of 4 Old 02-05-2012, 11:42 AM Thread Starter
anyone have any ideas?
post #3 of 4 Old 02-12-2012, 11:55 AM
Did you swap the 351 computer along with the motor? I'm not sure a 302 computer will run 351 electronics.
sgg93 is offline
post #4 of 4 Old 02-12-2012, 10:27 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
only the 302 out of older mustangs has same firing order as a 351, im not 100% on the correct firing order, but you can adjust it to go to the correct spot and it should run fine that way, good luck tho, and have you swapped the fuel filter on the frame rail? or pumps in the tank, those go out too, ive replaced 3 on my 95 f150 with a 351, and done a few filters on it too good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
