| Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!! |
bronco mods?
hey all, im in the market for a powerstroke, and im going to sell my dmax, and save up a for quite a few months, in the meantime im trying to pick up a cheap bronco. theres alot of 90s full size broncos near me rust free for the most part its going to have a 351 in it, im gonna lift it a little and put 33s on it, does anyone have any ideas for mods on the bronco, i was thinkin injectors, intake, headers and exhaust, and a superchip, to give it some giddyup. anyone have a bronco they wanna show off?
Definitely don't need bigger injectors.
First thing you gotta do is get the bronco. They have two different computer systems they can have. One is a PITA to work with. The other is great for power.
i know i dont need em but im gettin bigger injectors regardless, and probably a cam, intake and exhaust, headers and pipes.. . and thanks for the advice on the electrical, i saw your OBS build on here a while back man what ended up happening to it?
Bigger injectors are going to be a waste of money if you're not touching the heads, and if you get a speed density truck, they're not going to work right without a custom tune. If you get a mass air truck, you'll have to get a matching mass air meter to go with the injectors. Which are still going to be a waste of money. the 19lb injectors will support more power than you're going to be able to make on the stock heads |
it would run just as well w/ stock injectors as long as the tune is correct.
but if you want to waste money, get after it |
alright im just telling you my experience, but doesnt that go with anything? itll run just as well as long as it has the correct tune? so your telling me, if i get an OBS 7.3 and you get an identical truck, we tune em the same. theyll run the same. if i get bigger injectors, your telling me it wont make a difference until i do something to the heads? i beg to differ there.
you realize that a gas engine is very different from a diesel, right?
![]() when you put bigger injectors on a diesel, it will make more power... you add fuel to a diesel it makes more power. That power will also make more exhaust volume and that exhaust volume will drive the turbo harder, and you'll get even more power. when you put bigger injectors on a gasser without changing the engine tuning parameters, you LOSE POWER you can beg to differ all you want, but I've built/tuned a ton of EFI SBF engines. You asked for help, I'm offering it. If you won't heed good advice, then why ask in the first place? |
yeah i realize theyre different, and with the bigger injectors i gotta add more airflow to it also, but without touching the heads, it still will make a difference is all im saying. never did em on a 5.8 but i have on a 5.0 and a 350 sbc, and it makes a difference. now if i were to put a cam in it, and do some headwork on it, then it would effece it even the more.
