'95 F150 5.0L MPG help? - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 5 Old 10-09-2011, 08:01 PM Thread Starter
nccatfan's Avatar
Send a message via AIM to nccatfan
So Christmas is quickly coming upon us, and me and the wife want to get my father-in-law some upgrade parts for his truck. Any ideas on upgrades that'll help MPG's? I was thinking of hi-performance ignition coil with set of plugs and wires.
-'99 F250 7.3L PSD 4x4 (SCLB, 6-speed)
-'14 F150 4x4 5.0 CCSB
-'83 Ranger 4X4 5.0
nccatfan is offline
post #2 of 5 Old 10-14-2011, 07:31 AM
BubbaJ's Avatar
It really depends, Is it a Mass Air flow, or Speed Density 5.0? I can't remember the years on those trucks, for which was which... If your looking at a mass air, there is a lot you can do to it... Basically the more air you put into it, the more fuel it will put into it, you can get a noticeable difference in power just from a CAI, also you can look into getting maybe a MSD ignition, Plugs/wire's like you mentioned..and depending on your Savy with Engines, Throwing a cam into those 5.0's can do worlds of good... I know you said you want MPG, but when your looking at more power for these older trucks..generally the more power you have, the better MPG you can get.
Uhhh... Wait... What...
2005 F-250 PowerStroke 6.0 ** SOLD***
BubbaJ is offline
post #3 of 5 Old 10-19-2011, 09:40 AM Thread Starter
nccatfan's Avatar
Not sure which one it is. A cam would be more effort than I was wanting to invest (especially on a truck thats not mine. lol). But I was mostly wondering what the basic upgrades would do for MPG's. Thanks for the tips BubbaJ
-'83 Ranger 4X4 5.0
nccatfan is offline
post #4 of 5 Old 10-19-2011, 10:09 AM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Ignition is a good start, better spark means better burn. But if its got stock exhaust see if the cat is clogged up. Any kind of filter that needs changed should be changed. a CAI is good on mass air, kinda useless on Speed density as the motor doesnt know what to do with it really
Trucks and parts............
kanuck15 is offline
post #5 of 5 Old 10-21-2011, 08:24 AM
BubbaJ's Avatar
Thats what I Figured, But you'd be surprised as to the simplicity of installing a cam on a 5.0 mass air.. If you take the grill off, it can be done without pulling the motor..
Anyways, Like the above said, If its Mass Air, A could CAI and a good flowing exhaust (remove the cat) will help with MPG..maybe 2-4 mpg gained. You get yourself a good ignition set, replace the wire's and plugs.. clean everything up, Remember, A clean engine, is always a happy engine..
And Your welcome... I love the old ford Gasser engines.. I've got an 87 with a 450hp 351W, Carb'd and De-emessioned... and when I was in highschool, My Buddy had a 5.0 in a single cab shortbed 2wd... and with basically the mods I mentioned above.. with a little more work, We where running constant 14's in the 1/4
BubbaJ is offline
