Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Ford Gassers
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 08-17-2007, 01:09 PM
hamiltonsandm hamiltonsandm is offline
(Mechanics!!!) Escort Kicking my Ace....
I hope someone can help me. I recently was given a 97 ford escort that does not run. I have done everything I can think of here. It sat with an empty fuel tank for 1 1/2 years so I put ~7 gallons of premium in it and she fired up after much cranking. It smoked some white smoke for about 5 minutes and then I took it down the road. I made it about 1/4 mile and she died dead. Would not fire back up for anything. The fuel pressure is sitting right at 40 psi, spark is good and it WILL fire if I spray carb cleaner in the intake while turning it over. All my fuzes are good also.
SO...... Where else should I look? Could there still be water in the tank screwing with me here?
(I also changed the fuel filter, Couldn't even blow air through it.)
Thanks.
Old 08-17-2007, 01:13 PM
PatsPSD PatsPSD is offline
Change the plugs and air filter
Old 08-17-2007, 01:33 PM
Plugs were pulled and checked for spark, and Air filter is still good to go, even tried cranking it without the filter installed. Thanks for the quick reply though.
Anyone else?
Old 08-17-2007, 01:37 PM
Bad ignition modual there know for that
Old 08-17-2007, 01:39 PM
Big AL Big AL is offline
Strokin' In Dixie-Land
Something that you could try - pull the catalytic converter off - it may be stopped up. Doesn't cost anything for this.
Old 08-17-2007, 02:02 PM
When you say ignition module are you talking about the what I call a coil? (where the plug wires go?) If so I replaced this with no avail.
As for the unbolting the Cat, the car only has 40 thousand miles on it and it ran great for about 6 minutes. Still a possibility?
Old 08-18-2007, 06:13 AM
raveer2000 raveer2000 is offline
Resident Tire Smoker
Thanks.
That is a warning right there. The injectors are probably clogged or the filter could be clogged again. You may need to drop that gas tank and clean it out and blow out all the fuel lines.
Old 08-18-2007, 06:25 AM
owtcast owtcast is offline
I agree. If it fires when you put fuel (some sort of fuel) straight down the intake it is most likely a fuel problem.
Old 08-18-2007, 06:47 AM
WILLIAM LORCH WILLIAM LORCH is offline
Send a message via MSN to WILLIAM LORCH
You have a fule prob... If you have access to a ultrasonic cleaner this is good for the injectors. They have a micro screen in them and you willhave a hard time cleanning them without a ultra sonic cleaner.. Look at the entire fule system . CLEAN It from the injectors to the tank this should fix your problem Bill
Old 08-18-2007, 07:16 AM
SCUFFY828 SCUFFY828 is offline
SUPERDUTY GURU
fuel system clogged up may even have to replace injectors to get it to run,sounds like you pushed all the trash from the tank into the fuel system ,and clogged it up, being that you have good fuel pressure to the rail , thats why i say the injectors are clogged
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
