Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Ford Gassers
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 08-08-2007, 07:46 PM
desert racer desert racer is offline
F-150 quesition
I am looking at a 1996 Ford F-150 single cab with the 5.0 auto and was wondering if it would be able to tow this RVTrader.com - 2001 Carson FUNRUNNER - Ad Number 792954
Old 08-08-2007, 07:49 PM
robertcarmel robertcarmel is offline
Big Daddy!
You need to know the trailer weight. I may be wrong, but depending on the rear end (3:73) I think they had a towing capacity of around 5800lbs. A reese style hitch does wonders for towing, and you should also check if the truck has Trans, cooler as well.
Old 08-08-2007, 07:55 PM
I would insatll a trans cooler before even buying the trailer. Also it would be a hitch style with stabilizer bars as well.
Old 08-08-2007, 07:57 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
I know our 97 4.6L didn't like towing anything with much weight to it.. but it should be able to tow that fine..
Old 08-08-2007, 08:10 PM
Big Daddy!
They have raised the towing capacities recently on the 150's My first truck was a 1 yo 1979 F-250 351M (No PS, No Air, with Granny gear) her name was "The Red Head" and she was ... you guessed it Red in color! It didn't have the towing capacity of my 2006 F150. They have a towing capacity of 9000lbs, and the new 2008 F150 has a towing capacity of 11000lbs according to the Ford website. In my opinion the 5.0 had a little more balls than the 4.6 as a truck motor anyhow. I like the low end torque that the 5.0 made. Again, I know what ford says about the 4.6 over the 5.0. I had two 95's, and a 97. I liked the 4.9 & the 5.0 better than the 4.6! I liked the 4.2 V6 better than the 4.6! If some of the old tech are here, I think they can tell you better, but as I stated above I do believe that the towing capatcity was around the 5800lb area.
Old 08-08-2007, 08:16 PM
red73psd red73psd is offline
gas milage
Old 08-08-2007, 08:25 PM
Big Daddy!
Originally Posted by red73psd View Post
gas milage
I will give you that. The 4.6's get better mileage.
Old 08-08-2007, 08:29 PM
Tournaments Won: 1
the 4.6 sucked - gas mileage sucked too... 14 mpg mixed driving....
but thats why I said the truck he was looking at should tow it fine..
Old 08-08-2007, 08:38 PM
Big Daddy!
you ever have the 4.9L I6 fords? They did sip the gas THEY SUCKED!!! if mine got 14mpg it was being towed! But you couldn't kill them!
Old 08-09-2007, 11:54 AM
Ok so it should be fine towing a trailer similar to that with a quad or two and camping supplys for the weekend? Also what would my MPG with mixed driving unloaded?
