351w help - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 1 Old 04-07-2011, 06:01 AM Thread Starter
2wd_sled_puller_dmax's Avatar
351w help
I have got a 95 with a 351w in it and im having some problems im trying to track down. The truck has 208k on it and still runs pretty soild. The problem that im have is when i first got the truck and go WOT it would ping very bad and pour all kinds of black smoke out the exhaust. So i done a little reading and found out about the pill on the driverside. I took that out and right then it started to ideal smoother and no miss. So i just left the pile out. Now not everytime but sometimes when i pull up to a redlight or stop sing and have to stop and i go to give it gas to take off the truck will just die it sputters before it dies then its out. I will have to lay in to the floor and spin it over get it to fire and keep playing with it until i can get it back into gear to go. can anyone help me out here?
97 dodge 3500 flat bed 4x4 5x16 injectors 66 mm turbo dtt automatic
2000 Dodge 2500 2x4 all stock other then dtt tranny
2wd_sled_puller_dmax is offline
