Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Ford Gassers
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 07-20-2007, 02:03 PM
lifewitlooie lifewitlooie is offline
COLLEGE KID
Send a message via AIM to lifewitlooie
1999 expedition
looking for help.. my friends expedition is having problems.. check engine light came on. pulled codes. forgot number code . said engine is running lean. changed 02 sensor. engline light went away. came back on 2 days later. mass air flow sensor maybe?? need help thanks or a link to better info i could search through... maybe a flow chart or something for a lean running engine thanks
Old 08-19-2007, 06:53 PM
colo86GN colo86GN is offline
Mile High Strokin'
I have an 01 expedition. Just a thought, after you changed the o2 sensor did you reset the computer? Try pulling the battery and putting it back on, that usually works for me. Hope that helps!
Old 02-12-2008, 06:34 PM
Stan's 04 Stan's 04 is offline
I have a 99 expedition lite on system running lean look at the vacum lines by the pcv valve the always crack on the bends , make sure you take them off and look really good .
Old 02-12-2008, 06:40 PM
mschn99 mschn99 is offline
Banished
particularly the one that runs to the PCV valve...its a VERY common problem.....it needs to be tested for vacume leaks...
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
