- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!! |
'01 ranger?
Any body got any ideas? '01 Ranger 3.0L
P1450 Unable To Bleed Up Fuel Tank Vacuum |
| Sponsored Links |
Maybe this will help
P1450 - Unable to Bleed Up Fuel Tank Vacuum Monitors the fuel vapor vacuum and pressure in the fuel tank. The system failure occurs when the EVAP running loss monitor detects excessive fuel tank vacuum with the engine running (but not at idle). Blockages or kinks in EVAP canister tube or EVAP canister purge outlet tube (between fuel tank, EVAP canister purge valve and EVAP canister) Fuel filler cap stuck closed (no vacuum relief) Contaminated fuel vapor elbow on EVAP canister Restricted EVAP canister CV solenoid stuck open (partially or fully) Plugged CV solenoid filter EVAP canister purge valve stuck open VREF circuit open (harness near FTP sensor, FTP sensor or PCM) Damaged FTP sensor Jim |
Thanks Jim, I think it may be th fuel cap, I can hear it making a burping sound while running, don't know if thats normal. If not you gave me a good list to check.
| Sponsored Links |
