Tell me about the Ford V10 engines - Page 2 - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #11 of 30 Old 12-11-2010, 12:37 PM
I had a 04 v-10 that I traded for my current truck. I towed a 9000lb trailer weekly with it durring warm weather. Was powerfull enough but nothing compared to the diesel. I got about 6-7 mpg towing and no better then 9 in town and about 11-12 on the highway unloaded. i put a intake on it and a programer and that helped power and mpg but not by much. Only problems I had with it was it broke the flex plate and fried all the coils when i got a bad coolant leak spraying all over the place. I personally will pay the extra upkeep cost on a diesel long before going back to gas. The funny thing is my wife was the one that convinced me to get a diesel!
Sold the 6.0 for a 2015 6.7
MBRP 4" turbo back,
Accufab intake elbow,
SCT w/DP Tuner tunes,
RCD EGR delete,
EGT, boost, trans temp, fuel pressure gauges and scan gauge II
ARP studs,
Black Onyx head gaskets - they are gone and back to stock
6.4 banjo bolts
Crossover line
Dieselsite coolant filter
upgraded fuel regulator and other ford upgrades
Western MVP Plus plow
Snow ex salter
Jeckstine is offline
post #12 of 30 Old 03-09-2011, 08:18 PM
3V didn't come out until the 2005 started production. We got a 2004 V10 ordered on the last day in April 2004. Had we waited a few more days it would have been a 3V order and a 2005 truck.
In mid 2002 the heads were improved to provide more threads for the plugs. Put a little never-seize (just a dusting) on the threads and accurately torque them...they do just fine. If they loosen, they wiggle and destroy the threads...thus popping out eventually. They don't just blow out from a tightened state.
neil is offline
post #13 of 30 Old 04-16-2011, 04:00 PM
that is if the plugs were replaced at a high mileage, the carbon builds up on the plug and when you replace them you can pull the threads out, i dont know how often this happens though its just something to remember, and also the exhaust manifold nuts rot away and eventually you will need to be replacing gaskets and somehow pulling out all those studs to replace them too.
polish pete is offline
post #14 of 30 Old 06-18-2011, 05:44 PM
The ford V10 is a great engine. Gas mileage is not the best though. Very reliable. I've seen them in the 2, 3, and 400,000 mile range with no problems.
The diesel engine will pull better because it's turbo charged. The V10 is naturally aspirated.
Front Runner is offline
post #15 of 30 Old 07-08-2011, 10:05 AM
Hey everyone, came here surfing for some info on the 6.4s and ended up in a V10 thread, go figure. I have a 2000 excursion with the v10. Yes, there is an issue with the earlier ones like mine, where they may shoot the spark plugs out of the heads if they're not torqued down properly, because there are too few threads in the head. This, as it was posted was fixed in 02. The 3v heads have the opposite problem, their spark plug design has a long sleeve that in the earlier ones (05-07) can get stuck in the head when removing it. This problem is better known and documented on the 5.4s of that era.
I've changed my own spark plugs ~10k miles ago, and no issues yet.
As far as performance, it's the best gasser you can buy, hands down. Here's a very good article on these; and the results are very typical. It won't win many drag races, but i'll outpull any other gasser out there...
PickupTruck.Com - Part 3: 2007 PickupTruck.com Heavy Duty Shootout
The most interesting part, probably the diesel vs gas comparisson for each brand's offering:
7% grade
http://www.pickuptrucks.com/html/200...otout4mpg.html
15%
http://www.pickuptrucks.com/html/200...otout7mpg.html
Basically, it's the gasser that comes closest to a diesel, but it's no diesel.
As far as mileage goes, it depends a lot on the driver. When I switch vehicles in the fall and start daily driving my excursion, I usually get in the 10mpg range around town and 15hwy. I slowly get more and more used to driving it and will hit 12.5mpg city; gotta drive it a bit like a grandpa vehicle, but it is possible to get ok mileage out of them. Yes, 12.5 isn't anything to brag about, but compared to my old f150 or just about any gasser, it's not that bad. Doing it on 87 octane with 15 dollar oil changes, and 10 dollar fuel filters doesn't hurt either.
Fosters is offline
post #16 of 30 Old 07-15-2011, 05:27 PM
Send a message via AIM to PowerstrokeTech82787
Save yourself the headaches associated with the 3 valve V10s.
Theyre absolute JUNK. Ive replaced 5 entire engines under warranty. Due to cats plugging back feeding through the cylinders and really Fing SH!T up. Complete pan to intake. Put new motor in with new cats and update programming is supposed to fix it....
3 valves are INFAMOUS for manifolds. Well all gas V8s and 10s from ford be it 2 or 3 valve are infamous for the exhaust manifolds cracking and the studs breaking in the head. I had 1 3 valve V10 break off 17 studs before i even touched it! how the manifolds even stayed on is beyond me. TINY studs 8mm with 13mm nuts holding on chunks of cast iron? Great idea ford! Then put those steel studs in an aluminum head. Great.
And heres the best parts!
They use cam phasers just like the V8s do. They crap out. Just like the V8s do. They run the same Spark Plugs that the 5.4s do. The infamous ones that break off in the head and you have to spend hours trying to dig it out before pulling the head as a last ditch effort. Or spend a lil green for that AWESOME matco 5.4 extractor set. That works 100x better than the crap rotunda supplies us with.
If you want a gas truck with POWER and LONGEVITY Get a Chevy 2500-3500 with that bad @ss LY6 6.0 they rape V10s. (not that its hard to do my 5.3 will take on F250 V10s and rip em a new one) I know for a fact chained together, Chevy will pull the ford back@sswards every time. Plus theres a very noticeable throttle lag in both V8 and V10s from ford.
Now as for the new 6.2, that seems to be just as peppy in those heavy trucks as the V10s were...
PowerstrokeTech82787 is offline
post #17 of 30 Old 07-16-2011, 10:19 AM
ScottyP5947's Avatar
The plugs are known to break off in the head too. I just had mine done at the dealership and they broke 6 out of 10 plugs off in the head. Only a minor setback, the guy called it when he heard what he was doing with it.
We have a bunch of V10's in our fleet at work and they are pounded daily hauling generators off road and all over, we have had zero trouble with any of them. They just drink a lot of fuel. If work paid for diesel, I would never have the V10, but it's great for what we need them to do.
A gas Chevy? Sorry man, not for me.
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #18 of 30 Old 07-18-2011, 11:03 AM
mudfuel06's Avatar
Chevy 6.0 raping a V10 I pulled the same exact trailer with both trucks, Craparado on the way to the park, the V10 on the way back. Please hook up with me in your little truck, I would love to pull you all over the road. As for the throttle lag, I can go off the line with no problem.
2007 F250 Lariat Outlaw Edition-High Idle Mod,Sinister Coolant Filter
2001 Coachmen Royal 326RLS
2010 EB Expedition EL-The Wifey's
mudfuel06 is offline
post #19 of 30 Old 07-18-2011, 02:10 PM
Your 5.3 wouldn't even be able to keep up with some of the V6s from Ford...
Fosters is offline
post #20 of 30 Old 07-18-2011, 02:43 PM Thread Starter
Since this topic has come back to life, I will give an update. I bought a new F250, V10, in Dec. I love the truck. Price was great and it pulls as good as, or better than my old 7.3 when I need the power. Fuel mileage around town, just running errands etc., is at a steady 11MPG. On the highway at 65MPH it is right at 15MPG. When I do a lot of intown trailer towing, (my loaded trailer is grossing 7000#), I get 9.5-9.8 MPG.
I saved around $20,000 by NOT buying a new diesel Ford pickup. I can buy a little more gas for a LONG time with that savings.
I have not had one issue with the V10 YET. If I do have any engine issues, I am set to handle them. My son is a mechanic at the Ford dealer where I bought the truck.
I had 2 of the 2007 GMG 2500's with the 6.0 gas. Both were dogs compared to the V10, and both sucked as much, or sometimes more fuel that the V10. I will take a V10 any day to those sorry 6.0 GMC gassers.
mowingman is offline
