Diamond in the rough project pics - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 10-05-2010, 04:43 PM
Since I’m afraid to modify my 2010 PSD due to warranty issues and I’ve been itching for something to tinker with, I went and got this truck today. 1984 F-250 460cid 4 speed 4x4.
It runs- I drove 3 hrs back to the house with out it breaking down LOL, so that was good. I don’t know a hole lot about it but I DO know that it’s a low geared SOB and LOVES gasoline LOL.
It’s a diamond in the (very) rough but I think it will be fun to wrench on. Just thought that I would share my project with you guys. Wish me luck! I’m going to need it…
Diamond in the rough project pics-100_0974.jpg   Diamond in the rough project pics-100_0975.jpg   Diamond in the rough project pics-100_0976.jpg   Diamond in the rough project pics-100_0977.jpg   Diamond in the rough project pics-100_0978.jpg
Old 10-06-2010, 01:09 AM
Hey guys, after a quick glance last night I noticed this things got an electric fuel pump. It's carbureted with a Edelbrock carb. The part number is 1407, I looked this up and it’s a 750cfm manual choke. I don’t see a pressure gauge or pressure regulator… I was wondering what kind of pressure should be running to this carb and should I have a regulator at all.
This is just the beginning of a million mile long road with this gem - So it begins.
Old 10-06-2010, 03:52 AM
Comments?
Morning bump...
Old 10-07-2010, 04:17 PM
nice truck/project. 460ford.com has a good place to find out out about the engine. I hope to have a similar truck in my future. I am waiting to get a 85 f350 with an aluminum dump with low miles. I am really curious to see how you like the power and ride compared to your new truck.
Old 10-07-2010, 08:05 PM
Well this thing rides rough and is so freaking low geared that the ride is lacking to say the least. The power is more than enough. With the gears in this thing it’s wound out at 65mph. It need lots of work but that’s what I bought it for…to tinker with. I just hope it doesn’t need more than I’m willing to put into it lol. I’ve seen that it’s got an electric fuel pump with a carburetor and no pressure regulator. So maybe I need to get a pressure gauge and find what its running. It tends to idle a bit high until the throttle is feathered a bit (I'm told this could be too much fuel pressure). It seems to be hitting on all 8 but runs a bit rough. I’ve still yet to pull the plugs or anything as of yet. Played with the timing a little and the distributor was put in in a way that the vacume advance is hittin and won't allow for it to be turned any more- this may have something with it running rought too. I hope I can get to the bottom of the issue. The coolant needs flushed, well lets say it needs some coolant put in it. I checked and it’s just rusty water. I don’t think that there is any coolant in it at all. Valve covers are leaking so it makes things look pretty nasty on the top of the engine. The heater only works on the floor and on the second click of the fan selector LOL. The speedometer starts to work once you get to about 35mph. The lights all work… well I haven’t checked the back up lights and the head lights worked until I kicked the high beam selector switch in the floorboard. The seals are worn plum out on both doors/windows. I think I’m just going to find a salvage set of doors and slap them on there… and with having crank windows I don’t have to worry about the window motors.
I think I’m going to just go with a flat or semi gloss black for the paint. Maybe just “murder” this old big block FORD out.
Old 10-21-2010, 09:46 AM
Anybody know what years of the F-series doors will interchange with the mid 80's Fords? I thought that it was 80-86 but after looking at them maybe even newer models will? Maybe up to the early 90's? And what about the bench seat, will that be interchangeable with anything new than 86? Thanks guys...
Old 10-21-2010, 09:49 AM
drives a ranger
Send a message via AIM to kanuck15
doors you are stuck to that exact body style i believe. as for seats well the sky is the limit if you are willing to do some work
Old 11-29-2010, 06:44 PM
80-97 Ford trucks, all body pieces will interchange. Dash's will interchange with a little work, interiors will interchange. Basically, you can take off that stuff, and put anything from those 17 years in it and it will work.
Those 460's are nice, but the only thing you wont pass up is a gas station
I bet its got 4.10's. T-19's are direct in 4th, so with 4.10's at 65mph its roughly 2800rpm ish
Old 11-29-2010, 07:24 PM
Yeah, I don’t have a tachometer as of yet but running down the road at 65-70 (speedometer is jacked) I guessed the rpm’s around 3k so you’re probably right on the money. You know I had taken a picture of my truck and put it up against the picture of another truck from the early 90’s and it looked like the door would just bolt right up and now you have confirmed that for me and I thank you for that. I took the truck down to a local shop and had the rear differential, transfer case and transmission serviced. They told me that they couldn’t change the front due to the way it was built. I call B.S. on that- hell they could have at least sucked it out and refilled it. Oh well, I’ll do it myself. Oh and I flushed the cooling system as well. But I’ve got a gauge and regulator on the incoming fuel line now. It runs at about 3-4psi. There’s still a bit of a miss on it at idle. I’ve been working so damn much I haven’t had the opportunity to pull the plugs yet. Well… I did pull the front drivers side plug and it looked great. I just hope there’s not a week cylinder somewhere. I need to put some insulation down on the floor and then probably some rubber flooring. 1- It’s getting cold out and 2- That 4speed is noisy as hell with just a rubber boot between it and the cab. And then DOORS. These doors are just wore the freak out. The glass is still good but instead of replacing all the rubber and door panels I’m just going to find a set of decent all manual doors to bolt on it. Then give it a quick sanding and paint it flat black.
Fordguy, I might hit you of for some advice in the future being that you have a truck from this era. Thanks for the info, now to find a cheap set of doors to bolt on this thing
Old 12-03-2010, 07:40 AM
460s are badass. I have a 460 bored and stroked to 532 in my Fastback. Makes 514 rear wheel HP and 576 rear wheel tq, N/A. i was thinking of putting Nitrous on it someday.
