1998 f-150 issues.... - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 6 Old 09-23-2010, 05:38 PM Thread Starter
PowerSTOKED_Bryan's Avatar
hey guys, my brother has a 98 f-150 with the 5.4L v-8 in it. i think it has somewhere around 150,000 miles on it. the truck intermittantly runs rough almost like it is missing on one cylinder. the check engine light is on but the code is for Bank 2 running lean...i intend on replacing the plugs for him but was wondering if anyone else had any feedback? thanks!
2000 Ext. Cab F-250 Lariat(TOTALED)
2001 Reg Cab F-350 (mine)
AFE Intake
No Limit Tuning
4" straight pipe
2005 Harley Davidson Headlights
Early 99 Reg Cab (hers)
Tymar
Edge Evolution (temporary)
5" straight pipe
PowerSTOKED_Bryan is offline
post #2 of 6 Old 09-23-2010, 05:44 PM
Keel056's Avatar
Quoted: 4 Post(s)
If the plugs have never been replaced, I would replace allof them. If they have been replaced more than likely it is a coil pack.
Keel056 is offline
post #3 of 6 Old 09-23-2010, 05:50 PM Thread Starter
even with the code saying bank 2 lean? i was nervous and thought it was a fuel problem...
AFE Intake
No Limit Tuning
4" straight pipe
Tymar
5" straight pipe
post #4 of 6 Old 09-23-2010, 06:00 PM
Keel056's Avatar
Quoted: 4 Post(s)
It could be the injector. I had 98 f-150 with 98k that was missing realy bad so I replaced all plugs and back two coil packs 1 on the driver and 1 on the passanger side. The coil pack on the back drivers side went out 2 more times.
Keel056 is offline
post #5 of 6 Old 09-23-2010, 06:04 PM Thread Starter
ok i will start with the plugs and go from there...i hope thats all it is. any tricks for doin the plugs? looks pretty tight in there..
AFE Intake
No Limit Tuning
4" straight pipe
Tymar
5" straight pipe
post #6 of 6 Old 12-09-2010, 07:41 PM
dangerranger99's Avatar
bank 2 of what? bank 2 O2 sensor? faulty O2 sensors can cause that, and worse fuel mileage, because of getting a false reading, sending it back to the computer, thus giving wrong A/F ratio. Plugs is definatly a plus. i had a buddy with one that had over 200k on it, and he did have a spark plug blow out of the head once. but put it back in, and ran fine. Just be careful, and be thankfull its not a newer 3v 5.4, otherwise you can have over $200 wrapped up in just tools to get the damn spark plugs out. (my dad has one, and 2 broke off in head)
2004 F250 CCSB 4x4
True Blue
05 front end conversion with billet grille harley headlights and HID, EGR delete, 6.4 banjo bolts, rotella ELC, homemade coolant filter, 4 inch straight pipe, 6 inch stainless tip,2 inch pro-comp brackets, 3 inch rear blocks, Boost, pyro, fuel pressure, and trans temp gauges. SCT. 08 kr 20" wheels and tires
dangerranger99 is offline
