1988 f250 "TURBO" 302 mud truck in the process VIDEOS - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 9 Old 09-17-2010, 05:21 PM Thread Starter
helsel_182's Avatar
Send a message via AIM to helsel_182 Send a message via Skype™ to helsel_182
i started building this truck a couple of months ago and it has been a slow process but i havent spent a whole lot of money all of the parts i had laying around..... i have a civic that i was going to make into a racecar but decided to keep it stock and i used the turbo i had for it and put it on this truck ...... i still need to do some fine tuning , fix the leak in my charge pipe, get tire's, add a 3" body lift and another 3 inches of suspension so i can clear 47's, and maybe another coat or 2 of grey spry paint......
let me know what you think and if you have a youtube account subscride and i will be adding more videos as the project progresses
helsel_182 is offline
post #2 of 9 Old 09-17-2010, 08:16 PM Thread Starter
helsel_182's Avatar
this was when i first finished the turbo install
post #3 of 9 Old 09-18-2010, 03:57 AM Thread Starter
helsel_182's Avatar
bump......
post #4 of 9 Old 09-18-2010, 04:22 AM
pretty cool. are you going to plumb the wastegate to the stack or just let it dump in the bed?
08 250
cbienlein is offline
post #5 of 9 Old 09-18-2010, 04:45 AM
i assume this is your first turbo v8? just a pointer..you will need a bigger turbo. i would do a master power t70 with a .68 housing on it. you will be alot happier imo. looks good either way though.
'02 Ex cab SB
6637 filter
zoodad
3.5'' magnaflow muffler(freebie!)
diy ccv mod
smoked recons up top
16.82@78 with 2.2k weighing in at 7,035lbs
86 lx notch....more torque than the truck
408w and 101mm-9.27@134 lifting
86lxnotch is offline
post #6 of 9 Old 09-18-2010, 06:46 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 831 Post(s)
Feedback Score: 6 reviews
Pretty cool man, going to be keeping an eye on this thread. Keep posting your progress.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is online now
post #7 of 9 Old 09-18-2010, 03:22 PM Thread Starter
helsel_182's Avatar
i had two turbos laying around a 6.0L powerstroke turbo or this one i went with the smaler one because it was way easier to install and i can build 2-4psi with it and it doesent lean it out to where i would need to get a tune or anything..... its just a mud truck it will never see the road or over 35-40 mph for that matter.... just alot of redline....and rev limiter
post #8 of 9 Old 09-18-2010, 03:25 PM Thread Starter
helsel_182's Avatar
i am prolly going to dump it into the bed with it being such a small turbo it only builds like 2-4psi and the wastegate dosent open until8psi so basicly it dosent really serve a purpose as of yet maybe some time later down the road
post #9 of 9 Old 09-18-2010, 05:07 PM
well if it starts seeing the rev limiter it will probably grenade the motor. it will choke the motor, shoot the egt's skyhigh and cause the motor to detonate and bye bye. i am not trying to be a smartass here just trying to help a little. i have a decent amount of exp with v8's and turbos so i figured i would try to help you make it a litle farther. also check out The Turbo Forums.com and you will learn alot
'02 Ex cab SB
6637 filter
zoodad
diy ccv mod
