need help with 4.2 v6 - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
post #1 of 3 Old 05-09-2010, 03:35 PM Thread Starter
GnFnRs's Avatar
ok here's the deal.i lost my job,and lost my company truck.08 6.4 ps. so i had an old 98 f150 with a locked up motor and bought a motor from a 99.motor and trans went in fine.but they guy had cut the harness right at the main plug on the 99.so i figured i'd just use the harness from the 98.well nothing matched.all the plugs are different sizes. and there are lots more of them.so i get the plug from the guy i got the motor from and soldered every wire back color to color just as it was.problem again,there was an extra wire that didn't have another end.it's light blue,no clue what it does.after all this i start the truck and it cranks right up.but has a bad miss.i drive it down the street and it will only run 35mph to the floor.i start checking for fire at the plug and both middle plugs aren't firing.changed the coil pack cam sensor and crank pos sensor. still the same.
is it possible that the 98 computer just isn't reading the 99 sensors right? could i get the 99 computer and make that work? could it be the wire i couldn't find the other end to? it is either a light blue or grey hard to tell.
any help out there? need the thing running so i can get to job hunting
thanks
2003 excursion
6.0 psd baby!!
100% stock for now.
clean oasis report. not a single item till now.
76,000 miles when i bought it.
needed 2 injectors, y pipe, lower rad hose, egr valve.
now has 82,000 miles.
lovin every min of it
GnFnRs is offline
post #2 of 3 Old 05-09-2010, 06:09 PM
Powerstroke Techie
forddieseldoctor's Avatar
you should have changed the intake manifolds and all the sensors from the old motor to the new one. Even on transmissions when we have to install a used one I swap all the sensors from the old one to the new one.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #3 of 3 Old 05-09-2010, 06:27 PM Thread Starter
GnFnRs's Avatar
well when i bought the truck the motor was out of the truck and torn down to a stripped down to nothing.and i had never worked an a efi truck in my life lol owned a bunch but since they were fords i never had to work on them lol
2003 excursion
6.0 psd baby!!
100% stock for now.
GnFnRs is offline
